Question about Brother MFC 8500 All-In-One Laser Printer
Keep getting poor line connection - Brother MFC 8500 All-In-One Laser Printer
    Genius:
  • 1,018 Answers
I need some help here, please.
Define a poor line connection. How is the printer connected to the PC. USB (1 or 2), Parallel or Serially?
Don
Posted on Feb 06, 2010
How do I get it on my wifi network? it keeps telling me it is avoiding the network because of poor internet cinnection.
If you have poor internet connection problem with your WiFi, try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from ScanmySpeed.com before and after following these steps.
Dec 25, 2014 | Tablets & eReaders
How do i fix a code PO411?
Try to check vacuum lines, hose might be damage, or pitch.
check air pump connector might be loose, poorly connected.
Jun 02, 2014 | 2000 Cadillac Catera
Can't send fax. Getting transmission verification report stating NG: poor line condition/ out of memory. HELP!!
There are two possible reasons why your printer display the error message.
1. Poor Line Condition
- electrical interference on the line -Make sure electrical or electronic appliances do not interfere with the printer's phone line
- poor line connection - If you have a phone try connecting it directly to line outlet. Listen to the dial tone, if you hear noisy and static, then you will need to call your local telephone company cause there is a problem in your phone line. If dial tone is clear and stable then try checking the telephone line cord that you use to connect your printer from the line outlet, replace if broken.
- alarm system or another device on same line, these interferes with transmission / reception of the fax machine. Try connecting the printer all alone and then try sending a fax.
2. Memory Full
- There is no space to store incoming fax messages. Delete all stored fax messages.
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
My Brother mfc-665cw will not fax. It keep saying NG: POOR LINE CONDITION/OUT OF MEMORY
Check to see if you can make a call using the fax machine. This error can occur if you have no connection. It can also occur if your line is occupied or busy.
Oct 14, 2010 | Brother IntelliFAX 5750e Laser Fax
Sometimes my transmission reports say poor line condition att says my line is ok any ideas?
Unless you are paying for a "facsimile" line...the odds are that you are paying for a phone line and using a fax on it. The responsibility of ATT is to provide you with a line which meets phone quality. If you are getting errors due to occassional poor line connections these may not even be due to poor lines in your local area. See about getting your fax set to allow more "error" pecentage to be received before giving errors...probably need a service man for that adjustment tho".
Oct 11, 2010 | Brother Office Equipment & Supplies
Poor Line Condition message
If your fax has a handset listen to the dial tone and make a call if the connection is poor call the phone Co.
DickyO
Nov 09, 2009 | Brother IntelliFAX 1170 Plain Paper...
NG Poor line condition whenfaxing
If this is truely an issue involving poor line conditions you can try using a Line Noise Filter which you can get at most Radio Shack locations. Should cost about 14.99 or so. This could be caused by a loose connection in your home/office wiring or a loose connection at the switch box or anywhere along your line all the way to the tandum. If you actually hear static on the line have the telephone company do the work. Call in a bad connection issue and ask for a line test. If there is a grounded line somewhere that will detect the fault and they can better isolate where the problem actually is located.
Sep 08, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
''poor line connection''
THEY probably have their fax hooked to a DIGITAL phone line.
Aug 20, 2009 | Office Equipment & Supplies
Can't fax
check the cable has been put into the corect connector on the back it has to be put in the socket marked line.. if you have it in the other one for tel the fax cant hook up..Good Luck A
Jul 31, 2009 | Brother IntelliFax-2820 Laser Fax
Can not send fax
Call your telephone provider. There may be noise on the line. Ask you telephone provider to perform a line check on your line. If there is a problem they can fix it on their end. Worst case senario, they come to location as you have poor lines or old lines into your home.
If you have Vonage or Comcast Digital phone service, you will want to slow down your modem speed on the fax machine. Your manual should show you how to do it.
Jan 09, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC 8500 All-In-One Laser Printer Logo
77 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
