Question about IBM ThinkPad T30 2366 Notebook
I have 1024 megs of memory installed. bios shows 512
    Scholar:
  • 62 Answers
Check your laptop's memory sticks, one of them may be either loose or not working. if you're still within the warranty coverage, i recommend that you bring your ibm to the technical assistance. if not, try opening gently the ram sticks compartment and take both of em out, clean them with a eraser (only the connection pins), then, put them back in place. if the problem still persists, try changing their disposal and repeat the process 2 or 3 times, if it still shows half memory, then try removing one of the sticks and turn on the computer. when it doesn't starts, you've identified the faulty ram stick. replace it with a new one. oh, and by the way, a quick reminder, always ensure that you're working with your computer turned OFF, with NO BATTERY and DISCONNECTED from the external power, right? Glad to help!
Posted on Feb 06, 2010
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Ibm t30 bios shows 512 megs of memory i have 1024 installed
Hello my friend if is not something visual(like unconnected soldering pins on the motherboard)then you can not do anything else than change your motherboard.But if you compare the two slots and you see difference then you can connect this tire or pins with soldering gun.
Feb 06, 2010 | IBM ThinkPad T30 2366 Notebook
I currently have just 256mps of memory ram on my dell dimension 2400. i want to upgrade. my manual says the maxium is 1024 mbs. can i install 1gb of ram or should i get 512 mbs? i have windows xp os. thank...
1024 is 1 gig of ram. Some older motherboards require you to put in ram in pairs but I don't think your system is one of those but if you have manual or can download manual you should check to be sure. If you don't need a pair then yes you can remove the 256 meg stick and add a 1 gig stick or you can put in 2 512 meg sticks. Should run a lot better as windows recommends at least 512 megs of ram.
Nov 20, 2009 | Computers & Internet
Toshiba Satellite 1805-s253 memory upgrade
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
Mar 13, 2009 | Toshiba Satellite 1805-S253 Notebook
Toshiba Satellite Pro M15-S405 Memory upgrade problem
This usually happens when the laptop is not able to take more then a certain amount of memory, as the system BIOS does not support higher. By saying ACPI as the blue screen, that tells me that the power subsystem does not 'like' having more then 512MB of RAM. I am 95% sure this is your BIOS because of that information. Check and see if you can find a BIOS upgrade for your computer model, and that might fix the issue, if an update is available.
Jan 21, 2009 | Toshiba Satellite Pro M15-S405 Notebook
RAM Recognition 835GM PC Desktop
the memory is dual channel, so you have to use matched memory for it to work 1gig in each slot if possible, check the 1 gigs and 512's to see if they run at the same bus speed, if they are not matched there is your problem try a gig and a 512 in slot 0 to see if it picks the memory up, also there is sometimes an option in the bios to dissable dual mode
Sep 18, 2008 | Gateway 835GM (835GH) PC Desktop
Dell laptop memory install
available physical memmory is what all your programs on your comp is using like windows virus software drivers im thinking you probably have spyware or bugs in your comp that could be bringing memmory down
total physical memmory is what you just put in
May 09, 2008 | Dell Latitude C640 P4 Mobile Notebook
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
Incorrect Memory Count
Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount. __For example, 4 GB of memory size will instead be shown as 3.xxGB memory during system startup.____To use a DDRII 667 memory module on the motherboard, you must install an 800/1066MHz FSB processor.____Please also refer to the image below
Jun 14, 2007 | Gigabyte GA-8I945P-G Motherboard
IBM ThinkPad T30 2366 Notebook Logo
50 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
