Question about KitchenAid KSB3 Classic Work Top Blender
Blade not turning
After not using my blender for quite awhile, I pulled it out the other day and found that it wasn't working properly. When correctly assembled, the blade is not turning. When I disassemble and check the power without the blade/pitcher on it, the motor works just fine and the piece at the bottom spins. However, when I reassemble the unit, I can hear the motor running and see the blade slightly START to turn, but that's all. When I checked the piece on the bottom side of the blade attachment, it seemed a little hard to turn, so I used some vegetable oil to lubricate it. That did make the blade turn easier, but it didn't cause it to turn when the unit is assembled. Any suggestions? I feel like I'm soooooo close...
  • Susan Nowell Feb 25, 2008
    My blender has actually received very little use and is in "like new" condition -- except for this problem. Let me be a little more specific: on the blade attachment piece, the underside turns freely AND the top blade side turns freely. The problem is that when one is turned manually, the other doesn't turn with it. How do I get them to both turn together?
  • Anonymous Mar 16, 2014
    the motor turns on. the blades don't turn. I was able to hand turn them. Then, it would run. Now, they are not turning
I am looking at the same problem, the aluminum bottom part (on blade assembly) that contacts the black rubber on the motor part is no longer "attached" to shaft that drives the blade on top side. So like said the top and bottom "turn freely" but independent of each other.... not good, they should be one piece. Ebay does not have a replacement for this original part in my case and would have to buy a complete jar assembly. I will attempt to fix the original one by cutting a slot through aluminum and center shaft and dropping in a pin to make them turn together, with a spot of weld to hold pin to shaft... not sure how long this will last.... unless somene has a better idea to fix it?
Posted on Oct 29, 2008
The top rubber piece could be worn enough that it is not engaging the pitcher. look at it carefully and see if the "teeth" of the rubber disc on top of the base has not cracked and worn away. a picture of the new one can be seen on the parts websites to compare I spent $10.00 for my replacement but i found them at other sites for $6.00. you will need a very skinny 7mm open ended wrench to get the old one off and it is left handed threads that means clockwise will loosen not tighten the part.i ground down my wrench but an ignition wrench from an auto store will usually be thin enough to reach the flats on the shaft under the rubber disc
Posted on Feb 22, 2008
  • karl839
    karl839 Jan 31, 2013
    Where did you get the part?
I have had my Cuisinart SmartPower blender for about 10 years now and it has worked great. Recently there has been a black dust/stain/residue that is on the underside of the bottom collar/blade and on the...
At 10 years you are heading to replace it. With the blender bowl removed, try turning the connector the goes to the blades. Then do the same with the connector on the base. Whichever one doesn't turn easily is the one that is failing. Usually there is corrosion in the spindle of the jug and this causes tightness which in turn causes the connectors to shred. The tightness cause friction, which makes the plastic parts get hot. The blade should spin easily, the connector on the motor, not quite so easy. On some blenders you can switch the base on with out the jug being on it. Run it for 30 seconds and then switch off. If it stop dead, then problem is with the base and the spindle that goes to the motor. In a catering environment, I had a Hamilton Beach, shatter the base connector after 2 years. With blenders, you get what you pay for, Cuisinart aren't bad, but there are better makes if you use them a lot.
Aug 19, 2017 | Cuisinart SPB-7 SmartPower Work Top...
Bl 5000 replace support ring
e-mail the manufactor maybe they have some.
Jan 31, 2013 | Black & Decker BL5000 ProBlend Work Top...
I need a replacement viking blender blade (648204)
I found something on amazon, click here and take a look, it might be helpful: Amazon com viking blender blade. Cheers
Dec 02, 2012 | Viking Blenders
Where can I get replacement blade unit for Farberware/Salton blender model FBL500SS??
Available replacement parts for your blender are normally available online at the following site:
http://www.directpartsandproducts.com/blenders-fbl500ss-c-61_171_884_885_888.html
Unfortunately I do not see that a blade unit is available. I would recommend you contact this supplier directly to inquire whether a compatible blade is available.
Contact information can be found here:
http://www.directpartsandproducts.com/contact_us.php
Trust this is helpful. Thank you for using FixYa!
Jul 12, 2011 | Salton FBL500SS 3-Speed Blender
Blade won't spin
Check the blade with it off the base and make sure that it spins freely. Check the spindle on the base and see if it feels hard to turn. If the spindle turns too easy , then the connection inside the base is broken and needs replacing.
May 02, 2010 | Blenders
Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
The lights on my cuisinart blender come on but the motor just stopped working
Using your blade holder, turn the motor from the blade end. 1 or two turns. Tak the blade holder out, Plug in an test Sometimes the brushes in the mototor lose a good contact. SGood Luck -Ned-
Sep 19, 2009 | Cuisinart SPB-6 Smartpower 6 Speed Blender
Can't get drive coupling off bosch unversal blender blade fixture
what you need to do is hold the blades with a towel to protect your hand, then, use a visegrips needle nose to grab the coupling (pushing the guard down) and twist it loose. It may be very tight, when I loosened mine, the plastic portion of the coupling pulled off leaving the metal "nut" tight to the shaft. Either way, remove the coupling/nut in the standard "lefty loosey" direction. Many thanks to the people at pleasanthillgrain.com for walking me through the process. Blessings to you.
Mar 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Breville blender bbl550 stopps after 5 seconds any setting
Mine does this as well... 5 seconds of operation and then OFF.
My guess is this is a fail safe where the blender is turning itself off to avoid overheating and what could potentially cause this overheating is the blender is struggling to turn the blades. What could cause this struggling of turning the blades I am guessing is a lack of oil in the blades rotating parts.
If you hold the circular blade part and turn it, you'll probably find that its hard to turn? Mine is... and I oiled it up a bit and found I got a bit more usage out of it... although only temporarily.
Ideally I need to pull it apart and oil it properly.
Jan 29, 2009 | Breville BBL550XL 5-Speed Blender
VILLA WARE 5767
my blender jar is broken. I need to replace it
Aug 05, 2007 | VillaWare 5787 Double Smoothee Work Top...
KitchenAid KSB3 Classic Work Top Blender Logo
749 people viewed this question
Top KitchenAid Blenders Experts
eyecam
Lawrence Oravetz
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
