Question about Mitsubishi WS-65869 65" Rear Projection Television
Flashing green light will not stop, have done power offf an reset button, I saw in another site that you had a fix H159332, thx
SOURCE: TV Won't Power on Green Flashing Timer Light
Here's a guy who fixed it himself, with no prior soldering experience, and completely documented the process.
check it out here:
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
The only thing I would add, based on all the online Q&A sites, which all agree that replacing the seven (7) Capacitors on the DM board is the recomended fix, is to upgrade the Capacitors to:
1000 micro Farads @ 25Volt 105 deg.Celcius
Posted on Jul 26, 2008
SOURCE: green power light will not stop flashing and tv will not turn on or off
I'm having the same problem.  Did this suggestion work?
Posted on Nov 16, 2008
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on Apr 03, 2009
freetek
  • 5568 Answers
SOURCE: blinking green light tv won't turn on
I suspect both of you have a failed main power supply, this model may not be well-protected against brownouts or surges.
The main supply is usually a separate board and if you remove the lower rear panel, look for a board that seems to be related to the AC line and has larger components than the other boards. Some of them will be cylindrical and others block-like.
Look for a board number since this is a component that is often outsourced and may not be from the same manufacturer in every set. Call the nearest service center to inquire about repair or replacement costs.
Posted on Apr 03, 2010
Slinteriors
  • 8617 Answers
SOURCE: The green light on front keeps flashing an tv does
capacitors have failed. You can get the repair kit called the V26 Chassis DM/Power repair kit from www.tvrepairworld.com which contains the caps and the instructions.
Posted on Jun 20, 2010
I get a 'the ink absorber is almost full' message. how do i fix it. thx in advance
1. power OFF the printer, covers closed.
2. Hold down Resume button, press and hold Power button; Green lamp will light.
3. Still holding down Power release Resume.
4. Press Resume twice, release both Power & Resume and wait until lamp stops blinking.
5. When light is steady, press Resume four times; the indicator should be green.
6. Press Resume once.
7. Press Power to reset.
Jul 02, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
I have a flashing orange light and cant find the manual, I have changed the inks but its still flashing?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Dec 02, 2010 | Canon Office Equipment & Supplies
All lights are flashing
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
All the best Pineworks
May 01, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Pixma mp150 E5 flashing and b + c flashing and warning light on! have recently put in cartridge world inks but have already printed with them now its playing up each time you try to use printer.
Canon printers MP 160 AND MAYBE OTHERS
it.
procedure:
button pressing
the "service mode"
Try it
it.
Mar 17, 2010 | Office Equipment & Supplies
Resset ink absorber is full canon ip3600
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 08, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon MP210 error
and holding
move into a
Stop/Reset button 4 times, the specified number of
alternately in
button pressing
Jun 18, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
On Canon S9000 A3 inkjet printer error light flashing to indicate 'waste ink tank nearly full'. Can I fix this myself?
1. Turn off power.
3. Keep holding down Power button and let the
Resume button go.
4. Press Resume button 2 times then let both
buttons go.
5. Green light will flash then stop blinking.
6. When Green light is solid, press Resume button
4 times.
7. Press the power button and the printer should turn off. If not, press the Power button 1 more time.
8. Done.
Dec 04, 2008 | Office Equipment & Supplies
Green Power light keeps blinking and set won't turn on
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Feb 06, 2008 | Mitsubishi WS-55809 55" Rear Projection...
No picture, only the green light flashes on the 1080SI
replace DM
Jan 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
