Question about GE GSS23LGT 22.6 Cu. Ft. Stainless Side-By-Side Refrigerator w/Dispenser
My GE refrigerator dispenses water under the refrigerator
  • 36 Answers
Hole in water line, bad couplin, check by bottom hinge on freezer side. take toe panel off so you can check. also check lines and connectors around water valve in back bottom behind refrig. ck lines make sure not too close to compressor. this can shorten life of hoses.
Posted on Mar 05, 2010
Profile series pfs22slsbss water dispenser not working.
Fixing GE Side by Side Refrigerator Water Dispenser ...
? 4:00
https://www.youtube.com/watch?v=7G81-kJrqWI
May 24, 2012 - Uploaded by The Handyguys
But he then explains how he fixed his particular water dispenserissue by ... Refrigerator Repair - Not Dispensing Water through door- GE, ...
Nov 06, 2015 | GE Refrigerators
Recall ge refrigerator
you can do one of 3 things,if its still under warranty call for service,however if its not there is a heater element that installs in the water dispenser tube inside the door and wired to the dispenser circuit board at your expense of about $50.00 plus installation charge,or take a syringe and fill it with hot water and inject it up through the dispenser tube at the door spout till it melts the ice in the tube or use a handheld hair dryer VERY CAREFULLY so as not to melt the plastic tube and only melt the ice blockage,and live with it that way
Dec 03, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
No water coming out of the dispenser
Hello there and welcome to fixya
Dispenser Does Not Operate
  • 1 Ensure that the water supply line is installed according to the manufacturer's directions. Turn the water supply shutoff valve counter-clockwise to fully open it.
  • 2 Replace the water filter or remove the filter and install the plug. A clogged filter will prevent the water dispenser from functioning properly.
  • 3 Place a large container under the water dispenser. Press and hold the dispenser lever for at least two minutes to remove air in the water system.
Does Not Dispense Water
  • 1 Inspect the supply line and shutoff valve for clogs. Call a plumber to remove clogs in the line or shutoff valve.
  • 2 Replace the water filter cartridge or remove the filter and install the plug.
  • 3 Ensure that the filter cartridge is installed properly. Remove it and reinstall the filter cartridge. The cartridge will lock into place when installed correctly.
Read more: Troubleshooting GE Refrigerator Water ' eHow.com http://www.ehow.com/how_7170675_troubleshooting-ge-refrigerator-water.html#ixzz1XoEkLTk8
Sep 13, 2011 | Refrigerators
My GE Profile model psc23sgnabs leaks water from under the water & ice dispenser recess trim moulding. Is there any way to get the freezer door apart to replace water hose inside the door? There are...
No, the door is foamed together.
Remove small drip catch at bottom of dispenser area. Use silicone to seal recess along front edge and the two front corners. That should prevent water from getting under the door trim.
Mar 02, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Water is not dispensed, but ice maker works. This keeps happeneng . what can i do myself? model number GSH22JFRE SERIAL LH206147
It appears that GE has a problem with the water line to the water dispenser freezing up. I solved the problem by turning on the light on the dispenser. (Note, it is not an LED bulb). After about a day and a half the water began to flow again. Have not had a problem since then
Feb 16, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
Chasnge light for water dispenser
Dispenser
Unplug the refrigerator.
The bulb is located on the dispenser
under the control panel.
Remove the light bulb by turning
it counterclockwise.
Replace the bulb with a bulb of the
same size and wattage.
Plug the refrigerator back in and you are ready to go!
Thanks, Sea Breeze
Apr 25, 2010 | GE Profile Arctica Stainless Steel Top...
Ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Mar 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Refrigerator model #gss25sgress Water dispenser problem
What you describe was a common problem with this model and one that still pops up. Your refrig *might* qualify for an upgrade under terms of a program GE initiated a few years ago. Call 800-432-2737 first it might save you a service call
Jan 06, 2008 | Refrigerators
GE GSS23LGT 22.6 Cu. Ft. Stainless Side-By-Side Refrigerator w/Dispenser Logo
52 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
