Question about HP OmniBook500 250MB Zip Drive Module (F200960902) Drive
Bios password for Toshiba Satellite Pro 4600
I saw on you tube that it is possible to make a dongle to bypass the security bios password, it says to use an old printer cable and by cutting the wires and joining certain numbers together this will allow you to short out the bios security chip.
Could you please let me have the schematics of which numbers to join which numbers
  • campbellfms Jul 27, 2008
    After several years of use, when I turned on my Toshiba Satellite Pro 4600 computer, it asked for a password. This appears to be the BIOS password set a long time ago, which I no longer remember. Is there an alternative to paying Toshiba Tech Service department to reset/bypass the BIOS password?
  • Anonymous Feb 16, 2009
    say what cookin seems like i have the same problem all of a suden i havent used a bios password in ages what do i do now?i'm not afraid to open unit up is their a refresh pin on board i sure could use some feed back
    davidgalbreath1957@yahoo.com when powering up unit screen asks for pasword this setting is in the bios settings and cant get past the password to de-activate password option
Password: de toshiba satellite pron-4600
Posted on Jan 16, 2010
Try this. It worked on my 4300 series, but don't blame me if you brick your laptop.
http://www.laptop-repair.info/toshiba_bios_password.html
Posted on Aug 05, 2008
Toshiba satellite pro 4600 password bypass
Is it a bios password or windows password?
Dec 05, 2012 | Computers & Internet
Need to shut off bios password on my L300
Removing the BIOS battery will not reset the BIOS and remove the BIOS password.
On earilier model Toshiba a parallel port dongle will remove thw BIOS password.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.
Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Mar 29, 2010 | Toshiba Satellite Pro L300 Notebook
I have just purchased a shop soiled Toshiba L300D and the bios password has been changed and nobody knows what it is. How do I recover/remove it?
The BIOS password maybe able to be removed provided this laptop had a LPT printer port.
For details of a BIOS password dongle, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4350719-remove_toshiba_bios_password
Mar 20, 2010 | Toshiba Satellite Pro L300D-EZ1001V...
How to remove the cmos or bios password and want to remove the password in booting up, my laptop is toshiba satellite a135-s4527
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Mar 18, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite pro l 350 bios password reset
This is the ONLY other way, save paying Toshiba and filling in proof of ownership forms.
Feb 20, 2010 | Toshiba Satellite Pro L350-S1001V Notebook
Forgot bios password
Purchase a 25 pin male D sub connector and solder wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of a finished dongle.
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the finished dongel in the printer port and power up the laptop. You will be able to bypass the password and go into the BIOS configuration to switch off the BIOS password.
Mar 12, 2009 | Toshiba Satellite A100-S8111TD Notebook
Bios password reset for toshiba lap top
You need to build a hardware device that plugs into the printer port.
Get a 25 pin male D sub connector, and solder various wires
to the pins numbered below. The pins on the connector are numbered 1 to 25
For a picture of this hardware device (dongle) go to :-
Connect these pins together by soldering thin insulated wires to the following pins :-
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the dongle in the printer port and boot up the laptop, you will then be able to bypass the BIOS password and go into the BIOS to reset/remove the password.
Mar 08, 2009 | Toshiba Satellite Pro M10 Notebook
Password for windows 2000 on a toshiba satellite pro 4600
burn it to a disk put it in the disk drive turn off unit then fire it up and hold down the f10 button choose from cd and follow the instructions if you can not succeed then go to best buy spend 29.99 and have the geek squad reset it for you.
Jan 28, 2009 | Toshiba Satellite Pro 4600 Notebook
BIOS Password
I know on other toshiba's they have to connect it to a usb or lpt1 port with a special dogel that will remove it... some laptopps and desktops use a EEROM that even if you take out the cmos battory it doesnt allays reset it.. so you might have to ship it to mfg..
ps just to make sure you took out the cmos/bois battory not the laptop battory
I think I saw the video on youtube of the guy using the dongle but know clue where to get it nor any one I know has an EEPROM programer... sorry
Aug 05, 2008 | Toshiba Satellite A215-S7422 Notebook
Please refer to THIS SITE for help with your issue.
Jun 10, 2008 | Toshiba Satellite Pro 4600 Notebook
Computers & Internet Logo
2,697 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
