Question about Sub-Zero Bottom Freezer Refrigerator
Sub-zero 550. freezer icing
Sub-zero 550. the tracks on freezer drawer are continually icing. I thaw with hair dryer, but ices again within 8 =/- hours
    Sergeant:
    Champion:
  • 263 Answers
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 06, 2010
Sub Zero 700 TC with two freezer drawers on bottom. Ice sheet is forming on the bottom below the drawers and causing the drawer to stick. I have defrosted the freezer with a hair dryer and thought this...
How are the ice cubes? Are they normal size or hollow? I was wondering if some of the water was not making it into the ice maker and causing this issue. Is there any frosting issue not mentioned? Any water droplets on or around the back wall of the unit (inside)? I am a service tech certified and would like to know more about this issue. Have you cleared the drain completely, meaning after you de-iced unit, did you use water to verify the drain was cleared?
I you like to know more, so I can direct you in solving this issue.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 22, 2013 | Sub-Zero 700TC Bottom Freezer Refrigerator
Sub zero freezer drawer frozen shut
Subzero freezer: We had all our drawers stuck, including the ice drawer. We turned off the refrigerator, took all the drawers out and defrosted the rails with a hair dryer. The ice drawer was misaligned, so we reset the allen screws on the left to be the correct width. All better!
Sep 08, 2012 | Refrigerators
My sub zero refridgerator (freezer on bottom fridge on top) is cold on the bottom of fridge and warm on the top of the fridge. Any idea what is causing this. Items are also damp in fridge. We just vacumed...
the evaporator coil inside the freezer compartment is iced over and can't transfer cold air in thes condition,remove panel inside freezer on back side of freezer compartment and thaw it out with a hair dryer,then check the defrost heating element for continuity,if its open replace it,if its good, ,check the defrost control that powers the defrost heater
Jul 15, 2010 | Sub-Zero 611 / O Bottom Freezer...
Freezer drawer on sub zero stuck
chances are it is frozen stuck and also needs lubrication. Do this. Unplug it for an hour and try the drawer. If it doesnt open wait another half hour and try it again. When it does open, dry the rails thoroughly with a towel and then a hair blow dryer. Finally spray the rails with a lubricating spray like WD40 or better yet some white lithium lubricating grease, both products readily available at any hardware store, home depot, etc.
Oct 04, 2009 | Sub-Zero 650 / O Bottom Freezer...
Ice crystal formed in back of the refrig. how to get rid of this?
First of all, your freezer is freezing up DONT chip the ice!!!!!!!!!!!!!!! Either unplug the unit and allow it to thaw out naturally OR get a hair dryer or fan and let the ice thaw out. Then call us and we will be sure to get the right parts out to you to replace the defost system, which is out on your Sub Zero. We hope this does it for you and we also hope to hear back from you real soon. Ella
Sep 09, 2009 | Sub-Zero 690 Side by Side Refrigerator
Ice-maker thawing-refreezing into block of ice
Your defrost system may be out on this unit.
Aug 13, 2009 | Refrigerators
Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
Nov 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Cannot get ice drawer back on the track 500 series
Unfortunately, you need defrost freezer - put freezer thermostat on OFF. You possibly got broken ice tray or damaged sliders.Or leak in ice maker area. Till you defrost that compartment - no chance to pull tray out.
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jul 23, 2008 | Sub-Zero 632 / S
Sub-Zero 550 water leak and freezing
Seems to be a common problem with these units. You can get a drain tube heater ( got mine from an online refrigerator parts distributor), though may not totally solve problem. Some suggest running a copper wire through tube - supposed to conduct just enough heat to keep tube from freezing.
Sep 05, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero Bottom Freezer Refrigerator Logo
699 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
