I have a blown circuit board. Where would I find a replacement?
    Genius:
  • 1,018 Answers
You can search online for the manufacturer's replacement parts or you can call the manufacturer.
Don
Posted on Feb 06, 2010
My power shows good but no picture
This is likely a blown power board with secondary capacitors blown and not the primary. If your power board shows green LED and no picture then there is no power really going to other boards.
Check the power board for blown caps. This can be an easy fix and low cost if you are handy with a soldering iron and can replace caps.
Apr 13, 2015 | Televison & Video
33ef010gra
Sounds like a short, could be anywhere in the system. Check all the wiring for pinches or breaks in the wiring that could be going to ground or another wire.
Apr 03, 2014 | Heating & Cooling
Blown circuit board
You will need to remove the blown circuit board and replace it with a new one. Unless you know exactly what components are blown and have the utilities and material to replace the components yourself.
Oct 14, 2013 | M-Audio Studiophile BX8 Main / Stereo...
SAMSUNG SP-50L7HX DEAD FUSE BLOWN BLACK OBVIOUS SHORT CIRCUIT ANYONE KNOW ANYTHING IF BOARD REPAIRABLE O
Try shopjimmy.com who carries almost all the Samsung boards--if fuse right where power cord does come in trouble is right there.
Aug 30, 2012 | Samsung Televison & Video
Cuisinart SM55 circuit board replacement or wiring chart.
I have a Cuisinart 5.5 quart stand mixer. but its count down model does't work. it move as fold model when I push on button. I guess the circuit board was broken. Is my guess right? Where can I buy the Cuisinart SM55 circuit board and how to replace it?
Jul 23, 2012 | Food Mixers
Mine has 7 red blinks and wont come on. i pulled off the back and found a fuse blown on left circuit board, i can unplug the left circuit board from main circuit board thats in middle and tv will act like...
No, your done. Now replace the Y-Main, that's the large one you found the fuse blown on and replace the two buffer boards that the Y plugs into. Those are the two at the far left. The part numbers are on the boards. So that's 3 boards you will need. sometimes they sell the buffers together as a pair which is cheaper. DO NOT buy from second hand resellers. Always buy new when it comes to plasma sets.
Nov 30, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
VX924 Blown Fuse
What are the symptoms? How do you know the fuse was blown on the monitor you bought? The fuse on vx924 is soldered onto the circuit board. If you have any symptoms that require power its probably not the fuse. The back lighting on this unit has a problem. Three 25v 470uf caps on the circuit board are underrated and have a tendency to go bad. Replace them with 35v 470uf caps.
Sep 28, 2008 | ViewSonic VX924 19" LCD Monitor
Printed Circuit Board
Normaly they sell the complete circuit board for these units. If you have a part that is blown out, it is very probable that there are other parts that are damaged as well.
During warranty, they do not normaly fix these boards. They replace the board with a new one.
I would be looking at replacing the complete board. What will most likely happen and I have seen it often, is in this type of case, when a blown part is replaced, it blows again, because the parts that caused the failure must be also changed. I don't think you have the necessary tools, training, and design information about the circuit board to troubleshoot it properly to know the condition of all the other parts involved.
Sometimes there boards are rather expensive. You may find it more feasible to buy a new unit.
Jerry G.
Jerry G.
Jun 20, 2008 | Goldstar DH504EL Dehumidifier
Neither fan or compressor will com on
You have a short circuit in the system at some point. A blown fuse on the circuit board indicates a short in the control circuit. Tripping of the breaker indicated a high voltage draw from the compressor. Check the compressor motor terminals with the wires removed and the power off. Use an Ohm meter from a terminal to ground. You should have no reading. If you have any reading the compressor motor is shorted out and the compressor is done.
Jun 17, 2008 | Dometic Rooftop RV Air Conditioner
24 people viewed this question
jasbo
jasbo
