No hot water entering washer. (Stacked Washer/Dryer) Water is feeding to rear hose but not entering washer at all. Thought it could be clogged tried taping rear of waser intake hose fixture, no hot water at all. Figured I'd check with YouAll before I pull everything apart. :(
    Habit-Forming:
  • 84 Answers
Take the hose of the mixing vavle most likely it is clogged with rust or calcium,if not sounds like your valve is gone
Posted on Feb 06, 2010
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Hot water does not fill in the washer. The spicket has hot water.
There is an obstruction after the shut off to the hot water hose that feeds the washer. Shut off the hot water, disconnect the hot water hose from the washer, and hold the end in the washer tub. Open the hot water shut off. If now water comes out the problem is in the hose. Replace or clear obstruction. Make sure washer at hose end is in place before reconnecting to washer.
If how water flows, inspect the input hose connection to the washer. Some have a screen filter that my be clogged with sediment or other debris. Clean and try again.
If still no hot water, there is likely a problem with the hot water solenoid valve inside the washer itself. You'll have to remove and probably replace the valve or coil (or assembly).
Mar 09, 2011 | Maytag Atlantis MAV6000 Top Load Washer
The screen on my coldwater feed keeps rusting up
No, don't poke it through. It will clog elsewhere. Clean the intake screen completely. Buy a $3.00 in hose screened washer. Put it in the hose end connected to your taps. The reason cold clogs and not hot is that the rust settles in the bottom of the hot water tank and doesn't get pushed thru the lines. The cold water is a direct feed. Clean the newly installed screen monthly as your supply taps are way more convenient than the connections to the water inlet vavle at the back of the machine.
Jun 12, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
LTE6234DO Whirlpool Thin Twin-No hot water
The inlet valve that the hoses attach too the solenoid for the hot side may be stuck closed or clogged with sediment. May need new inlet valve.
Mar 18, 2009 | Whirlpool LTE6234D Top Load Stacked...
I have a Whirlpool stacked washer and dryer combination. The water is overflowing on the washer. It happens during the rinse cycle when the water is filling up. It appears that the cycle gets "stuck" in...
check the pressure hose. a kinked clogged or disconnected hose continues to fill. the pressure switch senses the air pressure in the hose.awaiting your further comments. thank you.
Dec 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Hook up
this one is simple. first connect the hot water hose to either inlet. now turn on washer for cold water only. if no water enters machine, you have it correct. now connect cold water to other one. now repeat cold water wash...does water come in?
Aug 17, 2007 | GE WSM2780W Stacked Washer / Dryer
Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Jul 17, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
