Question about Gateway FPD 1830 18.1" Flat Panel LCD Monitor
Screen stays black
Screen worked fine, after moving screen was not used for several months and now won't work at all. The power light comes on, then no other sgn of life.
  • Anonymous Aug 23, 2008
    samething
  • maaggenta Sep 21, 2008
    1 have same problem. i it the bulbs inside?
    Problem Solver:
  • 4 Answers
Http://25yearsofprogramming.com/blog/20070403.htm
this web site talks about replacing 4 capacitors, which worked for me. takes you through how to do it step by step.
i would suggest first checking the fuse labeled F1, right next to the capacitors. with power plugged in you should read 12volts on both sides of this fuse, if not it is bad and is probably the problem. solution is to just connect both ends of this fuse with a wire soldered to each end. you won't have fuse protection, but alternative is to just throw away, so what do you have to lose. mine works fine after this fix.
Posted on Feb 08, 2009
  • 52 Answers
Backlight is off. there is problem on inverter board.
Posted on Jun 26, 2008
    Scholar:
  • 53 Answers
The weakest spot in FPD1830 are four chip resistors located in the inverter board a bit above the middle, you can recognize them as they are bigger than others and located all four in one row. Holding by tweezers simply re-solder them to get rid of micro-cracks in the tin between pads and resistor contacts.
Posted on Sep 09, 2009
Black screen
Sounds like your screen is being switched to "Power Save" mode due to inactivity. This should switch back when the mouse is moved. This can take several seconds on a laptop. You can remove this "Power Save" by right clicking anywhere on blank desktop, select "Properties", "Screen Saver" and "Power Settings" then select "Always On" for the monitor.
Sep 13, 2009 | Toshiba TECRA 8000 13.3" TFT LCD Display...
Dell Computer Monitor - Black Screen
If it worked on a computer at the IT person, it is most likely a faulty graphics card in your computer. You may want to get that checked out.
Please vote if this helps.
nLinked
Computer Support Services
Jun 08, 2009 | Dell E193FP 19" LCD Monitor
Screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Feb 22, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Samsung HPS4253 Sound but no picture.
your backlight burnt out, this will be a maybe several hundred dollar repair. the screen is backilt by a very expensive flourescent light, without that light, the screen will be black.
Nov 28, 2008 | Televison & Video
JVC AV-56WP30 56 black screen blue light on no response
make sure your front panel lock in your menu is not lock if is then unlock it cause it will lock everything on the tv in front and can't move anything
Jul 15, 2008 | JVC AV-56WP30 56" Rear Projection...
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
LCD screen goes black repeatedly
Have you checked the light on your power supply? My monitor will go black and I noticed the light on my AC power supply was off. It was very hot so I unplugged it and let it cool down. When I plugged it back in my monitor worked fine until the power supply started to over heat again.
Oct 25, 2006 | Fuji FP-988D 19" Flat Panel LCD Monitor
Gateway FPD 1830 18.1" Flat Panel LCD Monitor Logo
433 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
