Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Screen has green smudges - Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Can dark smudged look on screen be a pixel issue?
Might be. Contact any service technician and make it confirm.
Apr 29, 2013 | Sanyo DP46849 46 in. HDTV
Tv has a pink smudge across the top of the screen and colors at tp of screen do't seem to align pink and blue and green. Tv was banged when carrying up 2 flights of stairs.
Your convergence has failed and need to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed.
You can get the parts and instructions from www.TvRepairKits.com
Apr 24, 2011 | Samsung HCN529W 52" Rear Projection...
My tv screen has several big smudges on it. I've
Use warm water and you have to rub for a while but not too hard.
The longer the smudges have been there the harder to remove.
DON"T use any other kind of cleaner.
When I bought my new Sony flatscreen, I was sold a cleaner for the screen. After reading the manual it says not to use anything other than warm water, so I return the cleaner to surprized sales people!
Jan 06, 2010 | Samsung Televison & Video
Have two dark smudges on screen
Dear Chaplink,
You said "two dark smudges on monitor screen".
Asumming that these smudges are digital and not just something tata you can remove with cleaner, If your moniter is back-projecting then the issue is probably that the projector has been damaged.
If your monitor is a flat-screen then the gels inside of it are misplaced from somone touching and damaging your screen.
So basically, the only practical thing you can do is buy a new monitor.
If i have been helpful, then please give me a positive rating.
Jul 04, 2009 | NEC MultiSync LCD2170NX-BK - flat panel...
Rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
May 23, 2009 | Samsung Televison & Video
Printing black smudges across the page at 10 cm intervals
Most likely cause by the drum unit. Replace drum or upgrade printer.
Jan 24, 2009 | Brother HL 1030 Laser Printer
Smudge looking marks onscreen
If you suddenly noticed it, this is most likely caused by a large piece of dust on the lens. It is hard to clean, you would need to take the whole TV apart in order to get to the lens (mounted on the optical block).
It could also be caused by a failure of the optical block, which had inherent issues. There is a pending class action law suit against Sony for problems with optical block that include smudges, hazes, and tints that appear after a certain number of hours.
Other causes could be a dirty portion of the mirror or a smudge on the inside part of the screen but these are rare because dust and contaminants do not usually accumulate on these parts of the TV.
Jul 14, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
19 people viewed this question
Jerry Greenberg
Jerry Greenberg
