Question about Canon DW 100 DVD-RW Burner
Are there brands of DVD that do not work in the burner? I followed instructions, but it said "cannot read disc." I also flipped the disc and tried that but got the same results.
  • 316 Answers
Hello my friend,you burner reads DVD-R / -RW / -R DL so if you have inserted anything else it can not read it,even DVD+R.
Posted on Feb 06, 2010
My drive cannot play any kind of disc, insert disc always appear
There could be a lot of reasons why your drive is not working properly. It could be that there is a service from your burning software that is not running properly thus affecting the CD-ROM. If you have any of these software, try un-installing them.
You can also try this for an automated fix from microsoft.
http://support.microsoft.com/gp/cd_dvd_drive_problems
Read and follow the instructions.
Hope this helps.
Jun 30, 2011 | NEC ND-6650A DVD RW Dual Layer Burner
Keep getting incompatible disc error
what if you try other dvd-r brands. just a suggestion.
Sep 23, 2007 | JVC Everio Share Station DVD Burner Burner
Driver cannot read blank disc
I recently installed a dvd writer for my neighbor. they used a top brand dvd-r / rw and never had any problem. but after the new install they had the same problem . after visiting the manufacturer's website we found that that certain brand of dvd were recommended. check the manufacturers site for dvd recommendations.
Sep 11, 2009 | Acer (4432A-002) CD-RW Burner
Wont burn audio cds.says the burn speed is to fast or discs are dirty or damaged. i have tried different brands of discs but is still not working.and have changed burn speed but still will not work
Hi...
What kind of burner did you use, are you using a nero burner, try to use nero or power to go, you can select them a a 32x and 52x.
You need to install a nero burner there are icon there that is usually a guide on how to burn you can read some instructions.
Regards
ICmanServer
Aug 01, 2009 | Computers & Internet
I have a gateway with windows xp and my dvd rom won't read dvd-r
it could be that your dvd drive is only able to read dvd discs not to burn them, if its a combo drive its very likely a cd burner that can read dvd discs.
if you send me the brand and model or the full name / details of the drive I could check on it.
Jun 03, 2009 | LG GCC 4320B CD-RW/DVD-ROM Burner
When trying to copy a CD, I get the following error message: Warning - Bad Master Disc!
I assume it means just what it says. The Disc you are trying to copy is faulty?
Clarify what you are trying to copy. If it is copy protected, A duplicator wont copy it. Or the disc was made in a format incompatible with the master drive you are using. Ive had drives read some discs and another drive that cant read the same disc. Some brands of discs work better on certain drives. Try to use top quality reccomended discs such as Verbatim.
Char S.
May 27, 2009 | LG 1 to 6 Target CD Duplicator 52x CDRW...
Dvd burner not working
It sounds like the DVD burner does not have a "write strategy" for the type of disc you are using. This results in the burner and the software having an endless argument about how to go about the burn!
You can either use another brand of disc more compatible with your burner or go to the DVD burner's manufacturer's website and check for "Firmware" updates.
The firmware is the software within the drive that establishes the write strategy for each type of disc and these are often updated.
If you do update the firmware then be sure to read the instructions on the manufacturers website carefully and follow them EXACTLY.
Jan 27, 2009 | Toshiba SD C2512 (SD-C2512) Internal DVD...
My samsung dvd rw combo is not reading any DVD. it is only reading cd.
To work around this issue, open Control Panel, and then follow these steps to configure the DMA/PIO settings for a controller: 1. Click Start, click Run, type devmgmt.msc, and then click OK. 2. Expand IDE ATA/ATAPI Controllers. 3. Right-click the controller that you want to configure DMA/PIO settings for, and then click Properties. 4. Click the Advanced Settings tab. 5. In the Transfer Mode box, click either PIO Only or DMA if available
Troubleshoot DVD problems loadTOCNode(2, 'moreinformation');
Step 1: Unplug any cables that are connected loadTOCNode(3, 'moreinformation'); a. Unplug any cables that are connected to the video outputs of the computer. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 2.
Step 2: Update the DVD driver loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain an updated driver for the DVD drive, and then follow the manufacturer’s instructions to install the driver. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 3.
Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer’s instructions to install the decoder.
Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. b. Try to read the disc again. c. If you still experience problems with the disc, make sure that the sound card in the computer is compatible with the DVD drive.
Note Hardware and software decoders usually need a sound card to play back DVD movies. d. Try to read the disc again. e. If you still experience problems with the disc, contact the manufacturer to obtain a new disc
Jul 19, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | IBM ThinkPad R40 2722 Notebook
NEC DVD-RW 16x DL
If you switched to a different brand of DVD's try using the brand you used before. DVD burners are tested with certain brands of DVD's and sometimes the brands that aren't on that list don't work.
Jun 11, 2006 | NEC 16X Multiple Format DVD+/-R/RW/DL...
Open Questions:
Canon DW 100 DVD-RW Burner Logo
390 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
