Question about HP PhotoSmart 7150 InkJet Printer
Trying to share a HP Photosmart 7150 that is connected to an workstation with XP. The laptop has vista
  • we4deals Feb 07, 2010
    The printer is connected to the Desktop PC and it is being shared. The laptop cannot access the desk top for some reason. I tried entering the ip andit does not recognize it.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sniper:
  • 81 Answers
If u have a router connect the printer to the router and it will be detected after installing the drivers on the sys.
If the printer is connected to the desktop pc than u need to share it with the laptop if the networking has been done or go aheaad and setup the network and than share the printer it would work fine
Posted on Feb 06, 2010
    Master:
  • HP Master
  • 425 Answers
IF BOTH SYSTEMS ARE VISIBLE; ON THE XP GO TO THE PRINTER PROPERTIES, THERE YOU WILL FIND SHARE CLICK ON IT AND FOLLOW THE INSTRUCTION.
HP photosmart used to print wirelessly from my Vista loaded laptops. printer was usb connected to desktop with XP. Had to get new hd and reload with XP for desktop and now cannot configure for wireless...
As your printer is not wireless itself I assume you shared the printer. To enable this again goto Control Panel on your desktop, select printers, right click your printer and there should be an option for sharing. Enable sharing.
Now using your Vista laptops you should connect to your home network (in your case this is probably a wireless router, as long as your desktop is connected to this router too), goto Control Panel, printers, add printer, search for printer not connected to this copmputer (or network printer).
Hopefully the Vista laptops will then pick it up and install it correctly. You may be asked to install the correct driver for the vista machines. Windows should provide you with instructions on how to do this.
Hope this helps,www.PuterCare.com
Feb 27, 2010 | HP Photosmart 2610 All-In-One InkJet...
Sharing printer
Make sure your desktop PC and the laptop are in the same Workgroup. You can view and change these settings if you right click My Computer and click Properties. In case your laptop joins a domain or workgroup at work, you might want to only change your desktop to match your laptop's settings.
Feb 07, 2010 | HP PhotoSmart 7150 InkJet Printer
I am trying to connect my printer 7150 to my pc hp pavillion 1644. I do not have the instructions.
See this page. Select the correct link for Vista or XP.
HP7150 Install
If you need additional help. Comment back.
Thanks for using Fixya.
Aug 18, 2009 | HP Office Equipment & Supplies
Can't re-load hp photosmart 7150 on windows xp. Gets to the point where the installshield should come up, lingers awhile, and then says check printer power and usb connection. The computer has already...
1.It could be the USB cable. Try a new cable.
2. Could be USB port, use another if available
3. You should be able to install the software without the printer connected.
4. Uninstall all hp printer software, and restart computer.
5. Delete any instances of the printer from the printer/fax located in control panel
Apr 15, 2009 | HP PhotoSmart 7150 InkJet Printer
How do I print Text vertically?
SELECT THE SIDEWAYS ICON IN THE PRINT SET UP BOX.
Mar 13, 2009 | HP Pavilion dv6000t Notebook
Hp Vista Laptop won't communicate with XP desktop when trying Prt
u have share your printer and add your printer in laptop u have to connect both pc in lan (local area connection ) or u can use the cross cable of lan when both pc connected then u have share your printer in xp then u have to add the printer in your vista laptop by using printer add visrd there is option on it u have to select the network printer & add it in to vista then u can print it
or
there is onther way u can install your printer in a laptop u need ur printer vista download
Jan 17, 2009 | Office Equipment & Supplies
CANNOT HOOKUP PRINTER , LOST CD
Here is a link to HP's website where you can download the drivers and software needed. Just select your operating system first...
HP Photosmart 7150
Nov 24, 2008 | HP PhotoSmart 7150 InkJet Printer
Downloading hardware
Simply connect your removable hard drive to a usb port of the computer with internet connection available, then open your browser and type www.hp.com.......>> go to software and drivers >>
put y our printer model >> Select your OS >> and download the drivers
Select SAVE AS.......and choose location on Your Removable Hard Drive........OK
Then unplug your removable Hard drive and conect to the laptop USB port.....
Then go to Start >> Control Panel >> Printer...........ADD A printer
Follow the instruction and Select ......Specify Location........Browse..........
And choose your removable Hard drive to finish install the drivers
for your printer
That's it.
Oct 30, 2008 | HP PhotoSmart 7150 InkJet Printer
Connecting Toshiba laptop using windows vista to C7180
Hi there i know that HP are updating a lot of the drivers at the moment you could try the following websites
www.hp.com (Free download)
www.drivers.com (Small charge)
I hope one of those helps but also try the XP driver as may vista might work on XP driver technology.
Thanks J
Jan 19, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP PhotoSmart 7150 InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
