Question about Watches
Replace rear cover on swiss army brand watch
Rear cover won't snap on and stay in place. There is one tiny notch on the rim, to clear the winder shaft, and I have made sure to align that properly before putting pressure on the cover.
  • 714 Answers
You are going to need professional help for this one.
Recommendation:
Take your watch to your local watch repair shop they have a watch press that will press the back cover on.
Hope this tip helps
Posted on Feb 07, 2010
Kaleido. How do I reinstall back?
The notch allows clearance for the stem so the rear should be positioned accordingly. Place the watch face down on a soft surface such as a towel. Position the rear with the notch centered around the stem and press it down with your thumb(s) to start seating. Use your jeweler's hammer (or equivalent) to tap the rear until it seats evenly.
Enjoy your revitalized watch!
Jan 28, 2016 | Fossil Watches
How do I put the back cover on a Waltham watch?
Try hooking the edge furthest from the winder at first, then work toward the winder.
If that isn't enough... warm the back cover with a hair dryer while you chill the rest of the watch. Serious as anything - the warmed cover will expand JUST SLIGHTLY while the cooled watch will contract JUST SLIGHTLY, maybe enough to snap that cover on. You can cool the watch in a freezer, but if you do... quickly snap the cover on while you hold the watch in the still-open freezer. If you take the watch from the freezer and leave it open at room temperature, it'll get moisture condensate inside. Leave it cold until the cover's on.
It also helps to wear cotton gloves if you use the heat-and-cool approach - then your hands won't appreciably cool the warmed cover or warm the chilled watch.
The watchmakers have a special watch press that squeezes the back into place - it's padded to prevent damage to the crystal, and applies a little extra force to the center of the back to buckle the rim outward just slightly during pressing. Like the opposite of a wheel cover for a car.
Jul 30, 2014 | Waltham Watches
Swiss army watch 241083, what battery does it take
Any Brand, Type 371 1.55v. I replaced the same Swiss Army Victorinox Infantry Watch model 241083 specifically with the Energizer 371BPZ Zero Mercury Battery. BTW, the replaced original was also a 371.
Jun 30, 2013 | Swiss Army Watches
Does the back cover snap-on/off or screw on/off? I don't see tabs for popping off.?
Although the cover is flatly closed and there's no tab/recessed area on the cover, you can still use a watchmaker's knife (looks like a Swiss Army knife but with case opener blade) or even use a Swiss Army knife to open it (pry off, particularly common in less expensive watch).
Be careful, don't try to use the point of the knife, use the blade instead.
Get under the rim and gently but firmly turn the blade upward, popping the cover off.
If the cover is flat, no notches on it, that is a screw-back case. You need a case wrench (screw-back watch case opener) to open (unscrew) the cover. If you try to use a very small flat screw drive and tab (turn) the cover in counter-clockwise direction, be careful because it can cut your fingers.
Hope it helps.
Feb 19, 2011 | Watches
Setting date on my swiss 200M women's watch
mcdevito75 here, If your watch has a stem (winder) it is most likely 2 position, Pull out stem to first position, this should allow you to change the date, set the date at 1 number before the actuall date you want, NOW pull the stem out to set the time, rotate the hands until you have the date and time for the actuall date.
Jun 29, 2010 | Swiss Army Wenger Sportedge Bracelet Watch
How to remove the back cover of the Swiss Army Victornoix pocket watch so to replace the battery?
The back will either have a small slot on one edge to pry it off or indentations around the perimeter for a case wrench to unscrew it. Specialized tools are used to avoid scratching the case. You best bet is to take it to a watch shop and let them do it. Most places charge between $3 - $8 to properly do it without damaging the case and they should also change the gasket to maintain water resistance if so equipped. Once you have it open you risk damaging the movement as you change the battery. It's not that it's a tricky procedure but you can easily damage something that will cost a LOT more than $8 to fix if you don't have experience.
Apr 09, 2010 | Swatch Irony watch
Can't get the hour hand or minute hand to move
If your watch is genuine SWISS ARMY made, then follow this link, choose your watch and download the instructions (movie style): http://www.swissarmywatches.co.uk/index.htm
Feb 04, 2010 | Swiss Army Wenger Victorinox Swiss Army...
SEKONDA: HOW DO YOU REPLACE THE SNAP ON BACK COVER?
Sorry, but your hands (especialy fingers) aren't strong enough. Nothing personal- just confirming the fact. My hands can handle 50 ATM casebacks, but I would say this is more expierence than strength.
OK, back to business: align the winder groove first and make sure this side of caseback sits in properly in case. Then use your thumbs to push the opposite side of caseback in, supporting the watch by your palms and knees. Do not try to push the caseback in bit by bit going all around the caseback. This sort of action will never work.
So, align the groove, support your palms by the knee(s) and push the opposite (to the groove) side of the caseback in to the watch case by one, but strong attempt with your thumbs. It should snap in.
If this doesn't work, you will need to ask the watchmaker to close the watch.
NB: Watchmakers are using specialized press for closing watch cases wich do not require any strength at all.
Rate me, please.
Mar 24, 2009 | Seiko Watches
Pry off back of eddie bauer watch
s this watch have little notches around the edges of the back? If not look around the edge for a LITTLE notch. Take a knife such as a swiss army, or one that has a little meat to it, and put it in the knotch and pry up. If you still have problems PLEASE tell me , and I will be glad to assist you.
Aug 13, 2008 | Watches
Wenger watch
swiss army watch had battery replaced after stopping, will not restart, replacement battery new and good.
Apr 22, 2008 | Swiss Army Wenger Alpenrose 70450 Wrist...
Watches Logo
114 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
