Question about Acer Aspire 5536-5224 Notebook
My screen is too dark. I pressed ''video playback'' on the tool bar and now my screen is dark. Any help?
  • Acer Master
  • 2,517 Answers
Hi there, please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. After the if you seen the screen dark then press FN+Right arrow in key board(>). When you press FN + ( < ) or ( >) key that's time its working for brightness controlling for screen. Now if all well then fine other wise please let me know .
Another suggestion is run your Acer driver DVD for installing Display drivers. When finish restart your laptop and watch whats going. If no success then format the Operating system & reinstall again.
Thanks & waiting for your feedback.
Posted on Feb 06, 2010
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
How do I get a "full-screen" playback (video) on
To get a full-screen playback on your Nikon D90 you have to play a video. Then, if you see sort of highlights or histograms, press UP and DOWN on the multiselector until you get your fullscreen view. It is probably to see thumbnails or calendar. In this situation, press OK at the center of the multiselector and then press UP and DOWN until you get to fullscreen.
I hope this will hep!
May 20, 2011 | Nikon D90 Digital Camera with 18-105mm...
Black screen in REC mode, bars across the screen in Playback mode
My advice is that you should by a DV cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Jul 20, 2009 | Canon ZR80 Mini DV Digital Camcorder
CANON MV850i WHITE BARS ON SCREEN ON PLAYBACK
good luck!
Luwangula
May 20, 2009 | Canon MV850i Mini DV Digital Camcorder
I have a 57x500 Hitachi ultravision digital t,v,.....When we try to watch DVD Movies or vhs,the screen has the dark side bars on the side,,how do adjust the screen to make the movies fit on the screen so...
On your remote there should be a button that says "Aspect" or "Pic Size". Press thisuntil the video fills the screen. If you do not have the remote of don't have the original remote, this setting can be found by preesing the menu button on the tv, go down to video settings and it should be listed under "Aspect Ratio", change it untill the video fills the screen.
Dec 30, 2008 | Hitachi 57F500 57" Rear Projection...
Gray bars on screen during video playback
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Nov 22, 2008 | Sony Handycam DCR-TRV17 Mini DV Digital...
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
Playback problem
I've encountered this exact problem a month ago, except cleaning the heads did not fix it. However, I was able to find an alternative solution...
After leaving my camera closed up in a drawer for a few weeks, I decided to take it out and leave it in the sun for 15 minutes, assuming that perhaps the gray bars were a result of moisture damage. The next day (Today, to be exact) I turned my camcorder on, and the gray bars have gone away from playback, as well as the reduced sound quallity it caused.
Apr 20, 2008 | Canon ZR800 Mini DV Digital Camcorder
BLACK Lines and having to reset.
i assume that the 'black lines' are 5 bars of dark video spaced equally across the screen. this is a symptom of dirty heads. use a mini DV cleaning tape, and the problem should go away.
Jun 09, 2007 | Panasonic NV-GS15 Mini DV Digital...
Acer Aspire 5536-5224 Notebook Logo
119 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
