Question about Canon Pixma iP2600 Photo InkJet Printer
The paper jams into the right corner when
The paper jams into the right corner when printing. cause I
got a piece of staple in there
and can't get it out.
Hi, just a suggestion, I had the same porblem and a quick fix for me was to open the top as if you were going to replace the ink and slide a thin business card in from the front to unblock the jam.
Posted on Feb 07, 2010
    Master:
  • Canon Master
  • 406 Answers
If you can get it out consult a technician to do that, because it is the cause of the paper jam and could also damage the drum if you continue.
Posted on Feb 06, 2010
Grinding noise coming from right side. having trouble printing and copying
Remove all paper from unit and carefully check in corners for a paper jam or staple/Paper clip
May 28, 2014 | Ricoh Aficio 1018D All-In-One Laser...
Dcp-8085DN keeps jamming
often there is a corner of paper or other paper jammed somewhere in the paper path. open up the paper path and look carefully throughout the path for small pieces of paper. sometimes a piece of a component could break off and also cause jamming.
Apr 06, 2013 | Brother DCP-8085DN Mono Laser P/s/c USB...
DCP-J125 Uable to print (36)
The message Unable to Print (followed by a two character code) will appear on the display for one of the following reasons:
- Dirty encoder strip
- Foreign object, such as a paper clip or ripped piece of paper, stuck in the machine
- Mechanical malfunction
The most common cause of the issue is dirt on the encoder strip. Clean the encoder strip by doing the following:
CLEAN THE ENCODER STRIP
NOTE: The images shown below are from the representative product. The customer's model may look different from the picture.
1. Locate a lint free cloth such as a T-shirt, DRY eye glass cleaner cloth, DRY monitor cloth or wash cloth.
DO NOT USE ANY TYPE OF PAPER PRODUCTS (EX: paper towel, tissue paper, napkin, filter, news paper etc.) This will help ensure the dirt is removed from the encoder strip.
CHECK FOR FOREIGN OBJECTS & PAPER JAMS
2. After thoroughly cleaning the encoder strip, look inside the machine and in the two corners for jammed paper or foreign objects and remove them if any are found. Pieces of paper may be jammed under the print head.
If the print head is locked to the right side of the machine, press and hold the STOP/EXIT key for 5 seconds. This will cause the print head to move automatically to the middle of the machine and allow you to look for debris in the right corner.
3. Leave the scanner OPEN and turn the machine around so you are looking at the back of the machine.
4. Open the Jam Clear Cover and look inside the machine for paper. Remove any jammed paper that appears; then close the Jam Clear Cover and turn the machine back around to the front.
5. Gently close the scanner cover and verify the error message cleared from the display.
If you cleaned the encoder strip ONCE and the message continues to appear on the display, clean the encoder strip again. It is common to clean the encoder strip multiple times to resolve the issue.
If you cleaned the encoder strip at least TWICE and the message continues to appear on the display, unplug the machine from the power outlet for 2 seconds and plug it back in to cycle the power.
TEST THE MACHINE
NOTE: After a paper jam has been cleared, the Brother machine may complete a 2 minute cleaning cycle to remove paper dust from the nozzles before printing.
May 01, 2012 | Brother Office Equipment & Supplies
Paper jams in heater
Hello
An overheated fuser is one of the most common causes of a paper jam. When large loads of print jobs are pushed through a printer, the fuser slowly starts to warm up. As the fuser warms up, the heat causes the corners of the printer paper to bend. The hotter the fuser gets, the more the paper bends. Eventually the paper bends so much that it causes the paper to get stuck in the fuser, causing a jam.
If you cannot find any other reason for a continuous printer jam, the problem may be the roller. A cracked roller can easily grab a piece of paper and get it caught. A glazed-over or dirty roller can also cause the paper to get caught on the roller and jam the printer. If the roller is cracked or glazed, you may need to call your print technician or replace the roller.
THANK YOU FOR VISITING FIXYA
Mar 03, 2011 | Ricoh Aficio CL7000DTL Laser Printer
I have a canon MP810 it is coming up with error code 6B00, what does this mean ?
You probably have something stuck in the paper feed or under the print head.
First try moving the print head left and right with the printer off. If that doesn't work then, Try looking for jam in the paper feed and specifically under the rollers. A small piece of paper or other debris, like fallen paper clip, staple. postage stamp are things I have seen stuck in printers that cause jams and error codes.
If these solutions don't work, post comment here.
j
Feb 21, 2011 | Canon PIXMA MP810 All-In-One InkJet...
WILL FEED PLAIN WHITE PAPER BUT WILL NOT FEED PHOTO PAPER
Follow the steps:
•1
Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
•2
Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
•3
Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
•4
Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
•5
Print your documents as needed.
Paper Cassette :
•1
Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
•2
Pull on the cassette on the bottom of the printer to slide it out of the printer.
•3
Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
•4
Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
•5
Slide the cassette back into the bottom of the printer. The printer is ready for printing.
Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
Work Center Pro 575 always gets paper jams
If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
Note: The power can be left ON when clearing a paper jam.
Typical Causes of Document Jams
Recommended Procedure
The document is fed at an angle.
Adjust the Document Guides to the edges of the
document.
The document paper is too thin or too thick.
Make a duplicate using a copier and use the copy
as the sending document.
Document has tape or pieces of paper taped to it.
Remove the tape or make a duplicate using a copier and use the copy as the sending document.
The Control Panel Cover is not fully closed.
Close the Control Panel Cover fully.
The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
Basic Troubleshooting
1. Remove all documents from the Document Support.
2. Open the Control Panel Cover.
3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
4. Close the Control Panel Cover.
5. Verify the display has returned to the Standby Mode.
Jul 13, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Jun 18, 2009 | HP LaserJet 1320 Printer
Paper is getting jammed hence not printing
Sounds like somthing is caught in the left hand side try looking in it with a flashlight and see if you can see somthing stuck like a twistie tie/sticky label/ staple / sticky tape.... If its in far try using a ruler or a few pieces of paper stacked together to dislodge it.
May 06, 2009 | Lexmark Z2420 Printer
Canon Pixma iP2600 Photo InkJet Printer Logo
127 people viewed this question
old marine
old marine
