Question about LG Cell Phones
When i connect a charger. after few seconds my mobile shows a warrning 'charge current is over limit.
  • 316 Answers
Hello,its a hardware over voltage protection use NiMH battery not Li-ion battery your charging voltage is over 4.3V,also you can try changing the charger
Posted on Feb 06, 2010
I have a IMC Heartway Gypsy and the power light blinks 5 times and the scooter won't run. I have just replaced the batteries. Is there list of what each code means? Thanks
1. Battery low
2. Battery charge is too low
3. Battery voltage too high or charger still connected
4. Current limit. turn scooter off for a few minutes and then on
5. Brake lever in freewheel mode
6. Throttle lever not in centre on switch on or faulty
7. Speed pot or throttle pot error
8. Motor volts error
9. Other internal fault/control fault
Hope that helps you.
May 18, 2014 | Pride Mobility Products Go Go Ultra X 3...
Screen is black all the time, can't turn phone on or off
1) Is your charger / adapter working OK ?
Most of the time, an adatper or charger contains a red or green LED, showing it's active, when inserted in the wall-outlet (110 / 240 V AC). In some cases, this LED will emit light, only when the mobile phone is connected.
If this doesn't happen, you might consider buying a new(er) charger for your mobile phone.
2) Is battery charged ?
No further discussion / c;arification needed.
3) Does phone contain an old(er) battery ?
If the mobile phone is used for a longer time or used intensely, the battery might be "worn out". A battery is able to be charged, but will show it's limits, because of it's maximum usage. With this I mean, they can be charged a maximum amount of times. If you even use a quick-charger, the battery may suffer more, resulting in a less longer lifetime. In such case you can replace your battery, by simply ordering / buying a new battery for your mobile phone.
Sep 03, 2013 | Motorola Mobility RAZR V3
Phone is using more current than the charger is able to deliver
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 02, 2012 | Cell Phones
I have nokia 3310 mobile i connect the charger and then mobile say reconnect charger pls solve my problam...
Possible that the charger is deficient in voltage and so is not delivering the required current for the battery to charge. You need to use a multimeter to check the charger, connect and measure the voltage at the battery terminal on the phone. It can also be a weak battery or shorted battery they can also show the symptom of no charging.
Ideal to get another charger battery from a friend to confirm before you buy one.
Mar 30, 2011 | Nokia 3310 Cellular Phone
When i connect my mobile for carging it show (not charging(stop)). But it show after few second and make a beep. with this mobile show different status of charge level.
Hi, I too have this cellphone, when this happened to me I just bought a new charger and that fix my problem. I would suggest you try first a known good charge for your cellphone and if still you have the same issue, try to visit a cellphone repair center or from nokia care center, because there is already a problem with the charget socket on your cellphone. Hope This Helps
Jun 11, 2010 | Nokia 1110 Cellular Phone
230 chauffeur doesn't charge. Batteries new and
hi, ok you mentioned nothing about the charger, is it built in ? or stand alone charger, can you try another charger ??
If you have a Electrical meter tester check that the charging socket pins do actually connect to the batteries if not check the charging socket,
of the three charging pins two are the positive & negative so should show 24 volts the odd one out the one in the middle just below the other two is the inhibit , that is normally grounded otherwords negative.
Sound like a loose connection so please check all connections if you are sure the charger is ok.
Regards
GeWiz.
Dec 10, 2009 | Electric Mobility Mobility Electric Power...
Will not charge or turn on using USB cable.
Two things.
HTC phones will not charge from the USB port unless you have ActiveSync on an XP or Mobile Device Manager on a Vista PC loaded.
Second, if the phone has been stored for a very long time, 1 year if initially charged, 1/2 year if not, the the battery self discharges to a point the USB port PC Sync software doesn't know the phone is connected. You must jump start a charge on the battery by either and HTC AC charger, a generic AC/USB charger will not work, or you can apply a +5 VDC voltage to the power terminal, marked + and - on the battery case, on the two outside terminals I believe. This 5VDC must be current limited for safety. The Red and Black lead inside a standard USB cable will supply current limited +5 volts at 100MA. Chop off a standard USB cable, their cheap and break out expose the Red and Black leads. While connected to the PC USB port, hold the Red lead to the + battery terminal and the Black to the (-), or other outside terminal, of about 30 seconds to a minute.
Now when you plug the phone to the PC with a good USB, the Amber light on the phone to indicate Charging, may not come on for a while, 5 minutes or so, but it will eventually. If it does not, jump the battery again for a longer period of time.
An AC charger for the 3125 are fairly inexpensive. $7 or so, on ebay with shipping. This may be the way to go. Consider getting one with a new battery. They are sold this way sometimes and sometimes for little more that the charger alone.
Oct 19, 2008 | AT&T Cingular 3125 Smartphone
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
Mda not charging
Either your battery is bad or your soldered contacts on the inside to the charger port are broken.
Jan 09, 2008 | T-Mobile MDA
Cell Phones Logo
143 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
