Question about HP Color LaserJet 2600n Printer
Printer adds pink to whole page
The error message I get from the people are :
The old one only prints pages in Magenta(The whole page gets pink). We have tried to change the cartridge and clean the printer without any luck.
As far as I can understand if it's a black and white letter, the page still gets printed in pink, and the black letters are printed as black.
The print server is a centos 4.4 machine, we have had no problem before using linux and it runs fine other places.
Chan qua hp a
Posted on Jul 22, 2008
    Problem Solver:
  • 6 Answers
Try to uninsall the sofware, and insall again...
Posted on Feb 21, 2008
My HP Photosmart c7280 will not print pink or magenta. How can I fix this issue?
Sounds very much like you have a clogged printer head you should run the deep clean procedure form the printer dialog. If that does not fix the issue you may need to replace the print head.
Jan 28, 2015 | HP Photosmart C7280 All-in-One Printer
What can be the cause for the complete page background being printed pale pink, including the Xerox own test page.
If it is a genuine magenta cartridge then try a drum refresh...
On the control panel of the printer: start the menu
Choose Admin Menu \ Maintenance Mode \ Drum Refresh
Once it has finished turn it off and on again and see how it goes. You may have a faulty drum though or even a faulty transfer belt.
All the best!
Oct 26, 2014 | Xerox Phaser 6125 Laser Printer
I have a Lexmark C522 Color Laser printer, all cartridges are showing as ok, no error messages but printed pages have specks of magenta toner on them
It sounds as though you have a leaking toner cartridge. If you aren't using Lexmark brand toner, that is VERY likely.. nobody seems to be able to make a good compatible cartridge. Test by replacing it.
Feb 22, 2014 | Lexmark C522n Laser Printer
Color Laser Printer Pink Tint
have you tried cleaning the charging wire and the transfer belt
Feb 17, 2014 | Ricoh Aficio SP C420DN Laser Printer
Hp 3600n laster printer has started printing pink blothes on pictures
You probably have a defective magenta cartridge. To test that you need Print Test Quality pages.
1. Press Menu to open the MENUS.
2. Press to highlight DIAGNOSTICS, and then press .
3. Press to highlight PQ TROUBLESHOOTING, and then press .
The message PRINTING... PQ TROUBLESHOOTING appears on the control-panel display until the
printer finishes printing the PQ troubleshooting pages. The printer returns to the Ready state after
the pages it produces are individual colors, black, magenta, yellow and cyan and a white page and a config sheet.If the defect is on all pages then it might be a bad transfer belt. If it is only on one of the color pages, that will tell you which cartridge is bad.
Mar 11, 2011 | HP LaserJet 3600n Printer
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
Pages printing Pink
Probebly a defective magenta cartridge.
Gerrit Jan
Nov 06, 2009 | HP LaserJet 3600n Printer
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp4650 replaced magenta ink but still getting magenta on the transfer roller and paper is pink in color
Once you replace the ink ,the printer prints an alignment sheet ,which is also a test page,
check if you have a message related with the ink onthe LCD of the printer.
You may run a cartridge test by going to
Hp Solution Center software. and print a test page from there.
for an easy resolution to this concern you may get in touch with www.techbuddies.org
as these people fix up your computer for free.
Ronald
HP AIO Printer Support
Jun 13, 2009 | HP PSC 1610 All-In-One InkJet Printer
Unwanted color printing
assuming you are using a browser have you gone to file page setup and uncheck the background printing of colors.
otherwise we need more info
OS , software application used, usb /network printer ,model printer
any changes made recently. etc..
Apr 02, 2008 | Computers & Internet
HP Color LaserJet 2600n Printer Logo
1,269 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
