Question about HP OfficeJet D135 All-In-One InkJet Printer
What printer do I use to connect an Officejet d135
What printer cable do I use to connect an Officejet D135 to a Compac computer? The connector on the hard drive is 25 pin. The connector on the printer is the old horseshoe shaped USB cable. I bought the printer about 5-6 years ago.
    Genius:
  • 1,011 Answers
A printer does not connect to a hard drive.
Is the connector on the PC a Male (Parallel) or Female "D" (Serial) shaped connector?
Does the PC have a flat USB connector you can use?
If it does, then you should be able to purchase a cable that has an "End Point Connector" The "U" shaped block and the other end is the flat conector that is oon just about everthing.
Don
Posted on Feb 06, 2010
Hp d135 all in one printer error message says "turn off and on" and all lights blinking fast
it's almost the (data cable) connected the carriage- it maybe damaged or not connected well.
Nov 29, 2012 | HP OfficeJet D135 All-In-One InkJet...
My hp inkjet d135 just uninstalled itself. What do I do?
what do you mean with uninstalled it self?
If the pc see the the printer and you dont have driver go to HP suite and download driver
if the PC didn't see the printer check the data cable
Apr 28, 2010 | HP OfficeJet D135 All-In-One InkJet...
My hp officejet d135 won't power up all of sudden
hi
make sure that your printer is connected to a direct wall outlet
firstly try a power flee,you can do this by removing the power cable and pressing the power button for 15-20 seconds.
also try resetting the printer using the partial reset
see if that helps.
Jul 14, 2009 | HP OfficeJet D135 All-In-One InkJet...
Officejet d135 Copier copies in 1/4
try to reinstall the driver of the printer, if nothing happen.
your problem in feed of the paper check the feed roller grears,
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp d135 copy function makes copy in green instead of black
ur tri color cartridge may have run out. change it and try again. if it doesn't work try calibrating ur scanner.
May 03, 2009 | HP OfficeJet D135 All-In-One InkJet...
Where can get power cord for hp officejet d135?
you can call
Contact HP or call 866-625-1176 to order power cord.
Mark
Mar 28, 2009 | HP OfficeJet D135 All-In-One InkJet...
I need to override my ink gauge for my tri color officejet d135
I don't think there is a way to reset them. If the color cartridge was change. The printer should purge is first and then read the gauge.
If it still showing empty, it could be the cartridge or the ribbon cable that runs it.
May 24, 2008 | HP OfficeJet D135 All-In-One InkJet...
HP D135 Wont Print IN COLOR!
Dacy, Go into the printer properties and check and see if it is set to print in grayscale.
Please let me know!!!
thanks
Feb 22, 2008 | HP OfficeJet D135 All-In-One InkJet...
HP officejet d135 delayed printing
Both the printer and the computer are machines and it solely depends upon the speed of the computer as to in how much time thye data is transmitted to the prinetr to print. Check the speed of the processor, RAM,USB port(if connected with usb cable), length of the usb cable /ethernet cable, distance of the router from the computer and the printer, size of the dcument/image.
Dec 24, 2007 | HP OfficeJet D135 All-In-One InkJet...
HP OfficeJet D135 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
