Question about Tricity Bendix AW1200 Front Load Washer
Error code tricity bendix aw1200w washing machine
Can you tell me what error code 7 means please
I think this is a problem with the thermister (built in to the heating element assembly).
Posted on Jul 27, 2008
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix aw1200w washing machine does not always drain water ! What is wrong ? Thank you in anticipation .
i think something is floating around in the space between the inner and outer drums
like a sock or small plastic bag etc etc etc
so drain the machine
take the back panel off and remove the heating element and shine a torch inside
the blockage may have worked into the drain system pipes and traps
and you may need to totaly disconnect it and
lay it over on its right side {the side opposite the soap drawer}
then examine its outlet from the drum and pipes to the pump
the pump
and its housings and viens
for any wires and hair clips monopoly hotels and 2ds and 3ds platic pens
basically anything that fits into the soap drawer and fits down the intake pipes
that then lives inside the drums
so... taking the heating element out will expose the area you need to check with a torch
also if you shine a bright light thru the open lid of a washer
you can usualy see any implaled wires etc on the outer drum
most are transparrent or opaic
Dec 10, 2014 | Tricity Bendix Washing Machines
Blocked drain pump
get a air compressor at the drain end and blow air up the hose to try unblock what ever could be over the sensor. OR get your garden hose and force water the other way to try unblock
Jan 05, 2013 | Tricity Bendix Washing Machines
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Tricity bendix aw1001w has an unknown error code, the led labled end flashing 3 times, any ideas?
It could be one of the E30 codes which would relate to the pressure switch or an earth fault on the heating element there could be a wiring fault or p.c.b. fault check wires off heater at bottom rear of machine,remove back plate 4 screws.Hope this helps.
Good Luck.
May 07, 2010 | Tricity Bendix AW1200 Front Load Washer
Manual for tricity bendix 1000
Please try here:
http://www.serviceforce.co.uk/pdfs/U23248.pdf
If this is your model (there are 5 models with the same name) please rate my response.
If not, please let me know and I will find the link for your model.
Thanks.
Feb 24, 2009 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1001w
is the door locking if not replace it.
Nov 23, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1200 Front Load Washer Logo
272 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
