Question about Desa International GWP20T GLOWARM Wall Mounted Panel Heater
We polyurethaned a floor now our propane gas heaters, when on smells terrible
  • Desa Interna... Master
  • 2,522 Answers
HI it sound like the smell ha sgot in to the fire open the windos and try and burn the smell off but keep a eye on it when you do this , just for safety
Posted on Feb 06, 2010
Smell emitting from gas heater
Carbon monoxide is completely odourless and every sort of combustion of a carbon or hydrocarbon fuel produces carbon monoxide. That is why heaters should not be used without adequate and efficient ventilation and heaters should be kept in good order because efficient combustion produces less and inefficient combustion produces more.
Inefficient combustion and the need for service can often be recognised by the characteristic blue flame being tinged with yellow.
Heaters burning inefficiently often produce a smell for the sensitive or stinging eyes but that is not caused by carbon monoxide.
The gas itself is also odourless and the characteristic smell is added to warn people of leaks. I think the added gas smell tends to settle or separate from the liquid gas to some extent so there will be times when it is so concentrated it isn't entirely neutralised by the burning process, at least that is my theory.
Jun 18, 2017 | Heating & Cooling
A strong smell of gas when first comeson
Absolute danger>>>>!!!!!!!
You absolutely must call gas company immediately.
They will turn off gas to water heater immediately.
Leaking gas appliance is extremely dangerous.
If you have propane, the gas is heavier than air and will settle to floor. So you can be standing in an invisible puddle of explosive gas and never smell it.
If you have natural gas, the gas rises to ceiling. The entire ceiling cavity can be filled with explosive gas, but you only smelled it briefly before it drifted upwards.
Do not delay getting this problem repaired by professionals, or fixya might lose a customer.
Sep 08, 2012 | Rinnai Water Heaters
Last year we had all the siding on our tv, trailer, replaced due to hail damage. When we finally got our trailer back from the rv repair shop we have had nothing but problems with our Atwood hot water tank...
Immediate danger!
You have a gas leak.
Propane is heavier than air and will settle on the floor.
The floor can be covered and ignite and you will not smell it while standing or sitting or laying in bed.
Absolutely open the door and leave trailer. Turn off the gas to the heater if the shut-off is outside.
Possibly you have a bad gas control valve. This should be repaired professionally.
Aug 08, 2012 | Water Heaters
Came down stairs water heater off and pan filled with water
Copy following link for troubleshooting leaking water heater.
http://waterheatertimer.org/Leaking-water-heater.html
You posted question under propane gas heater.
Propane is heavier and air, and this type gas water heater should not be installed in basement (below grade) since gas leak can fill basement with explosive gas.
Water leak does not cause gas leak, so water leak is separate problem.
Recommended for propane safety: install gas detector close to floor near gas water heater
Regular Natural Gas heater, install gas detector higher on wall since NG is lighter than air and will rise.
Aug 04, 2012 | Whirlpool 40-Gallon 6-Year Gas Water...
Terrible smell and burns my eyes from 5gallon tank. First 5gallon tank was find as is small Coleman bottle . Can propane be bad from Supplier. It gives off sour smell and irritates eyes when burning?
I would not use it any further, I cant say if anything is in the gas, I doubt it, However the propane at too low a pressure etc, can cause this, dont use it with eyes butrning ever!
May 28, 2010 | All-Pro Propane Garage Shop Heaters - All...
Pilot lights but heater does notstart burning it sounds like everythings starting up its about 15 years old worked fine then one night smelled some gas shut it off next day would not work its propane
its most likely dirt/rust in your burner assy , but as its 15 year old and propane do your self a favour and get it inspected by a registered gas/propane engineer .
ive witnessed propane explosions at first hand and they are scary
Oct 23, 2009 | Dayton Gas Fired Heater LP TC200VA - Heats...
HEATER WAS WORKING FINE TILL I HAD PROPANE TANK TOPPED OFF
The Pressure Regulator may be stuck, Try closing the propane valve releasing the pressure,, gently tap the regulator( on the propane inlet side) and Very Very slowly open the propane tank valve, and attempt to light
Jul 30, 2009 | Hayward H Series
We just replaced the propane gas line. Our stove is gas and it lights, but neither of our gas water heaters will light. Both water heaters are new and have been working for about 4 months before the...
You have to purge the air from the lines.
At the water heater, take a wrench and loosen the gas line until you smell gas coming from the line. Then tighten the gas line. Check it for leaks with a soapy water solution. Let the gas smell clear, then light the pilot on the heater.
May 25, 2009 | Heating & Cooling
Oven over heats/gas smell
Hi the fact that you smell gas near the floor suggests you do indeed have a gas leak, propane is heavier than air to will fall to the floor.
you really need to get the gas company to check
Mar 14, 2017 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Desa International GWP20T GLOWARM  Wall Mounted Panel Heater Logo
78 people viewed this question
Top Desa International Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
mcijoe
Level 1 Expert
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
