Question about Sony KDF-E55A20 55 in. LCD Television
We are trying to replace bulb on our sony kdf-e55a20. located lamp housing but can't get it out. what appears to be a silver hex nut is holding the left side of housing unit preventing the unit from sliding out...help
  • 10,594 Answers
You need Hex Key to remove hex screw on left side of lamp then take out lamp.
Sony original lamp is supplied with hex key, please check lamp box.
If you do not have hex key, try small size flat screw driver to remove hex screw as flat screw driver could fit into hex screw.
Following exploded view shows how to remove that screw with hex key.
Hope this info will help you.
Thanks.
Posted on Feb 06, 2010
I have sony kdf-e55a20,turns on pic is great but every minute the screen gose black and then comes back on,green lite stays solid and no red lite,can someone help me with a solution?
I have seen a bad lamp do that but Sony has a Factory bulletin out on a similar problem caused by a defective thermostat which is located on the top of the lamp housing
Nov 10, 2012 | Sony KDF-E55A20 55 in. LCD Television
I it easy to cange the lamp in my e55a20 sony tv. I have one coming 2moro, and was wondering the difficulty level.
It involves removing a housing an pulling out the bulb then inserting the new bulb and replacing the cover. Sony has excellent instructions in the owners manual:
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=KDFE55A20
pg 76
Mar 02, 2011 | Sony KDF-E55A20 55 in. LCD Television
I have a Sony KDF-E55A20. I just replaced the bulb, the old bulb was broken. I replaced the bulb but the TV still does not work. There's a series of 3 blinking red light. What does this mean? After I put...
Put lamp cover back on tv as it will push a safety switch inside then tv will turn On.
Lamp cover is first thing that you removed to replace lamp in tv.
Hope this will help you.
Thanks.
Nov 17, 2010 | Sony KDF-E55A20 55 in. LCD Television
How do i replace the lamp bulb in sony tv kdfe42a10
There are several online video tutorials that are available online. If you search some of the websites that seel the lamp, most have a tutorial.
You'll need...
1. a Phillips screwdriver
2. a 7mm (I believe) nut driver
3. Needlenose pliars
4. Gloves to keep acid from your skin getting on the lamp. The company I bought my lamp from provides cotton gloves (www.bulbsolutions.com)
Remove 3 screws from housing (2 on each side, and one that holds front of housing to the back of the housing)
Remove 2 mounting screws in corner of lamp that holds lamp securely to the lens.
Remove nut holding wiring harness to lamp
Remove screw holding wiring harness to lamp
Nov 08, 2010 | Sony KDF-E42A10 42 in. LCD Television
Need instruction for KDF-E55A20 lamp replacement
Click Sony Support to download user manual of KDF-E55A20 that has lamp replacement procedure in details.
Sep 24, 2010 | Sony KDF-E55A20 55 in. LCD Television
How do you replace the lcd bulb on 55 sony
Here's how to replace a bare lamp w/ out buying the housing(it's a little bit cheaper that way)
http://www.youtube.com/watch?v=xFUVTwPD1HM
Here is how you get the lamp out of the tv...
http://www.youtube.com/watch?v=Eqm59DTodp4
it's much easier to buy the lamp already in the housing and change it that way.
Sep 02, 2010 | Sony KDF-E55A20 55 in. LCD Television
Screen turns off and on Sony KDF E55A20
It is symptom of dying lamp and tv requires new lamp.
Existing lamp in tv has reached to end of its life span and causing that problem. If lamp has not been replaced in last 2-3 years, just put new lamp in tv to get it back in business.
Thanks.
Jul 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
Picture goes out, comes back, sound is fine
I found several instances of this probllen on various forums, and determined that it is the bulb after all. It seemed that a bulb should either work fine or be burnt out, so I thought it might be something else, but so many other customers had this identical problem that I am 99% sure it is the bulb. I found a replacement bulb with housing for about half the price of the Sony Store, so i ordered it. In the meantime, another customer offered a suggestion to try adjusting the Power setting to Power Saving instead of Standard. I tried this last night and the picture worked fine! I will replace the bulb when it arrives and keep the old one on hand in case this happens in the future. Thanks to all of the posters out there!!!
Dec 07, 2009 | Sony KDF-E55A20 55 in. LCD Television
How can I replace the lamp myself? It is for a Sony KDF-E55-A20 rear projection TV.
Lamp replacement is not so difficult in Sony KDF-E55A20 and its procedure is written in user manual.
You can download free copy of user manual by clicking Sony Support.
Jul 24, 2009 | Sony KDF-E55A20 55 in. LCD Television
How do I get to the bulb?
You can buy Original Lamp for your Sony KDF-E55A20 from Sony Accessories (Official Website of Sony) by entering model number as above in search box.
For your information, Lamp (bulb) part number is ...
A1085447A* LAMP BLOCK ASSY XL-2200U and price is approx $200
Thank you.
Oct 03, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20 55 in. LCD Television Logo
32 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
