Question about Husqvarna Garden
Three Husqvarna parts needed
Three queries please - all in urgent need of a solution. 1. I have a Husqvarna 45 chain saw and the toothed plate that is used for leverage (alongside the chain bar) has sheared and bent. I need a replacement. (Part number 5060149-01H?)
2. I also need a replacement nut of the pair that fasten the chain bar into place.
3. I have a Husqvarna R52S mower and need a new plastic grass deflector that converts the mower into mulch mode. Part number 187535 CAV1?
    President:
  • 2,220 Answers
Have you tried your friendly neighborhood Husqvarna dealer? We are not a parts supplier. You seem to have part numbers. I will gladly provide a link to where you can find IPLs for your equipment and verify part numbers. If you use your local Husky dealer there are no shipping and handling fees, he might have the parts on hand, and because he is an authorized outlet there will be no warranty issue should the need arise.
HusqvarnaUSA.com (45 about 6 pages in, did not try the mower, should be there too)
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Good Luck Howard HTH
Lou
Posted on Feb 06, 2010
When sharpening the chain saw chain what is the filing angle?
same as the angle of the chain. It is recommended you use your round file that accommodates the size of the tooth of the chain. count the cuts or motions (each tooth should be filed the same amount) if you cut the first tooth three times cut the balance three times. keep the exact angle of the tooth and do not deviate or the chain will not cut as well. if you over file and change the angle for the chain you are filing you may need to have a professional fix it or buy a new chain. the flat file is simply a light stroke to remove misc fragments off the top of the tooth or give it a sharper edge after the round filing is complete. when using a round file it is easiest to purchase a small holder so each stroke is stable and straight. good luck.
Oct 25, 2014 | Worx Wg303 16" 3.5-hp 14.5-amp Electric...
Which ignition can I fit to my 3120xp 2012 Husqvarna that is unlimited?
I am running the ignition unit from the old Husqvarna 444 part no. 501681501 not sure if this is still available, its much easier to mod the K1260 ( power cutter ) this you can use the 372XP unit, it is possible to fit the unit from the 254XP but this involves drilling an extra hole in the units core, does your machine have two screws holding the unit or three? they may have started useing the crankcase from the power cutter on the later 3120. With a non governed unit you will hit a lot more than 12500, the carb has a fixed main jet, you may have to change this or open out the original
Nov 19, 2012 | Husqvarna Garden
Parts_Diagram_For Husqvarna Electric 16 chain saw
A parts diagram is available here:
http://www.husqvarna.com/ddoc/HUSI/HUSI1999_AAaa/HUSI1999_AAaa_I9900039_.pdf
Oct 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I am looking for a part for my electric chain saw model number em235 I need a new 6 tooth drive sprocket for this model. It is a 2006 make.
Check
http://www.mfgsupply.com/ChainsawSprockHusq.html/mv_session_id=w6YXsBDX
You might consider using a Husqvarna sprocket since the sprocket on the Husqvarna EM235 should be an exact replacement for the McCulloch EM235.
Apr 18, 2011 | McCulloch Vacuums
Looking for a repair manual for husqvarna 136 chainsaw
Below is the link to the Husqvarna website where you can download a repair manual for free. Click the link and just find the year of your chain saw and you are good to go!
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=136&types=O
Oct 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need manual for husqvarna chain saw parts
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 03, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
What size file should I use ona Husqvarna 137 chain saw?
The question you ask is dependent on the chain in use not the saw that drives it. To determine what chain is installed we must see the chain. A local seller/mechanic should be willing to answer your question. Lowes will not know!!!
Excerpt from "How To Sharpen a Chain Saw" here follows:
http://www.grounds-mag.com/mag/grounds_maintenance_sharpen_chain_saw_2/
Use the right tools
If you're holding it correctly, a proper-diameter round file simultaneously restores the three different angles of a saw-chain cutter. Different-sized chains and different cutter styles call for different file diameters. It is vital to use the right size file.
In general, 1/4- and 3/8-inch-pitch, low-profile chains call for a 5/32-inch file; 0.325-inch-pitch chains require a 3/16-inch file; and standard 3/8-inch-pitch and 0.404-inch-pitch chains demand a 7/32-inch file. Beware, however, because many exceptions exist. For example, some brands of standard 3/8-inch-pitch chain require a 3/16-inch or 4.5-mm file. Check your chain-saw owner's manual or saw-chain instruction sheet to determine the correct file diameter. If you're not sure, ask your dealer. He also may have literature showing the proper filing angles and special procedures for your chain.
Getting the angles exactly right is not as important as removing all damage from the side plate and top plate and making sure the critical top corner is really sharp. However, for good results, you must consistently hold the file at the correct height and orientation within each cutter. This is difficult to do without some type of file guide.
Like most tools, simpler is better when it comes to file guides. The best guides are plates that drop over the chain. These keep the file at the right height and attitude and have witness marks to show proper top-plate angle alignment. The best thing about this type of guide is that you can see what you're doing. Guide plates that clamp to the file and rest on the cutter top plate also are good, but they tend to obscure your view of the cutter. Whichever guide you select, make sure you get the right model for your chain.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 15, 2010 | Husqvarna Garden
I need to know the right angle to sharpen my chainsaw
If your saw still has the original bar and chain, it was supplied with a .325" pitch chain and you'll need a 3/8" round file with a sharpening guide to properly sharpen it.
Here's a link to the Husqvarna site to the Rancher 455 models so you can select the correct manual to download, that matches your particular saw, based on the year of manufacture, etc.
There is some excellent information about maintaining your saw, along with a really good guide with step-by-step instructions for proper sharpening.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=455&types=O
If you're having trouble figuring out the right manual for your saw, use the online Customer Support page and they'll reply.
Hope you find this Very Helpful - Best regards!
Aug 19, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Chainbreak refit
Enter the model number of your saw here:
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=&types=I
Click the "Illustrated parts lists" and use it to reassemble your chain break. If you aren't able to reinstall it using this guide your friendly neighbor hood Husqvarna dealer will happily fix it for a nominal fee. HTH
Lou
Aug 08, 2009 | Husqvarna Garden
Found a part loose in my husqvarna chain saw
The "Illustrated parts lists" for your saw are here:
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=350&types=I
Try to identify the loose pin on the drawings. If unable to identify where it came I suggest your visit your local Husky dealer. Please advise me where it belonged once it is repaired. TIA
Lou
Apr 18, 2009 | Husqvarna Garden
Garden Logo
253 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
