Double check the cables for your hard drive. That will be the Hdd cable.
make sure the pins fit to the hole. After that check if it is detected if not.
Load defaults in BIOS. If it still doesn't detect it try using another cable for
the hard drive if you have already done that try using another hard drive.
If that works then it only means you need to replace you hard drive.
