Question about Reebok Exercise & Fitness
Even after I tightened the belt, my 8400 C Reebok
About one year old, it has serious slipping problems. I weigh 185 and run sort of fast (sub-8 minute pace). Even after I tightened the belt, my treadmill slips. Too loose or too tight? How do you adjust correctly other than trial and error?
  • judw630 Feb 06, 2010
    Well, it did send me to another website, and on to alot more to read... so I wouldn't call it a "solution".
  • judw630 Feb 07, 2010
    I have tried to open the motor compartment and it isn't obvious how to do that without breaking it. I am not comfortable doing something that might void the warranty. So I am now in touch with the manufacteurer/distributor, ICON Fitness. Their customer service folks have emailed me and I will go that route. Have a good day...
  • 2,926 Answers
  • GetMeOttaHere Feb 06, 2010
    There was so much info on this site and so many different procedures, it was best to send the site. Also, you will have to test components with a volt meter, I was not sure if this was something that was understood or a task that could be done, providing me with info to resolve.Volt readings and external power supply connections were paramount for testing.
  • GetMeOttaHere Feb 07, 2010
    Excellent to hear the treadmill is under warranty. This will make things a whole lot easier for you, and while the Tech is there you can watch and observe the repair procedure to pick up on a few things for yourself in the case of another future problem. Thanks for using FixYa.
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
The belt is sliping as I walk or run
* take nail polish or paint and place a mark starting on the front roller pulley and going onto the front roller metal shaft
* then try to walk on it and see if the white mark separates
* if it does then the roller is bad and would need replaced or tap screws placed through the pulley into the metal shaft to hold it in place
* if it doesn't separate then the drive belt is slipping and most likely will need replaced, although you could try spraying belt dressing on it to see if that would be a temporary fix.
* if neither of these is your problem and the walk belt is slipping then you will need to try to adjust the screws in the back of the treadmill through the end caps. these are allen wrench screws.
Tighten each one the same amount such as 1 full turn to start with.
see if you can now walk without it slipping.
If not then tighten 1-2 more turn on both sides.
If after 2-3 full turns it is not tight enough
I would recommend replacing the walk belt.
Hopefully this helps with your problem!
Aug 02, 2010 | Reebok 8700 ES Treadmill - Silver Service...
Reebok treadmill
Hi James
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
May 24, 2010 | Reebok 8050 ES Treadmill
Reebok 8050es treadmill walking belt has started slipping/skipping. It has been oiled and it is 2 years old.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
May 05, 2010 | Reebok 8050 ES Treadmill
The belt is sticking on my treadmill reebok TR3 (RE-11303). What do i do to stop it from sticking?
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Mar 28, 2010 | Reebok Exercise & Fitness
I've got an i-run machine and when I tried to
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Then,plug in2_bing.gif the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Mar 01, 2010 | Reebok New York Giants Eli Manning Jersey
Reebok Vista belt not working properly
There could be 3 different problems with this machine.
1) loose drive belt (this model has a spring loaded idler that tightens the tension)
2) Bad front drive roller (you wil hear the pulley spinning freely on the front roller if the roller is bad)
3)Last is possibly the walk belt itself. May need to be tightened or replaced.
To try to tighten the walk belt, go to the end of the walk belt and find the 2 adjust allan screws in the end and tighten them 2 revolutions clockwise on both screws.
Hope this helps a little. Tim
Nov 25, 2009 | Reebok Vista Treadmill - RBTL13305
GE front loader does not go into final fast spin and does not drain.
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. It sounds like you may have a slipping (loose or stretched) v-belt. See if you can get the back off and look for a way to tighten the belt. This is a frequent problem. The built in a way to tighten the belt.
Nov 24, 2009 | GE WSXH208A Front Load Washer
Treadmill belt slipping
Mar 22, 2009 | Reebok Exercise & Fitness
Treadmill may be slipping
Depending if this is a new issue or old, It could be a couple of issues. Check the belts for slipping. Proper tension on walking belt (check your manual) or drive belt -remove the cover and you might be able to see if the belt is slipping or it could be a load issue (electronics not sensing added load fast enough). My bet is belt tension. Also Lubricate,lubricate,lubricate
www.twincityrepair.com
Feb 28, 2009 | Reebok Exercise & Fitness
Exercise & Fitness Logo
136 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
