Question about Intel D915GAV Motherboard
No power up no fan only motherboard led
Same trouble on two GAVL and one GUX ; tested with 2 cpus and various PSU and different DDR and DDR2 for GUX...
any idea of what causing this trouble ? thanks...
  • nexus7 Feb 21, 2008
    Could you be most clear ? are you telling me to use a "hairdryer" on the southbridge chip ???.
    board were not on a case, I just try to test it before building
    computers (these boards are brand new, but stayed in box since 2 or 3
    years),
    could bios "deseappered" after battery life ended ???
    Thanks...
Its the power Supply. Even though it is powering the LED on the mobo, it isnt able to supply enough power to run the PC. Most likely a diode in the AC to DC Rectifier Bridge went out, and is now causing a malfunction in the rectifier bridge.
I've had this same problem on 2 different PC's. Swapped power supply and it fixed it, both times. Good luck, hope this helps.
Posted on Mar 26, 2008
    Problem Solver:
  • 6 Answers
The broblem is in the south bridge, some it can be re heat using hot air..
Posted on Feb 21, 2008
Biostar g41 m7 wont power up after installing cpu
have you an ATX/BTX PSU?
with 24pins ATX + 4pins P4 connector?
if you haven't that it's normal that's don't work
else your PSU 5Vsb or/and your motherboard are dead
Nov 19, 2012 | Biostar G41-M7 Motherboard - Socket 775,...
Dell precision 650 dies...
Hi , I suggest try testing single memory modules , one at a time to isolate a faulty module if that is the issue
Another idea is running a Linux live distro os like Ubuntu from bootable disk or flash drive in live/try mode which run from a virtual partition on the ram memory
If Linux runs ok - then likely a Windows related driver / software issue but if same crash issues are observed then most likely a hardware device issue ie faulty memory module , but as varies when crashes i am thinking more the psu - high boot current load demands due to twin SCSI drives , video card etc - old psu - after a few years the power current rating reduces I recall -25% typical , discrete components not so resistant to heat - try to test with a known good high performance psu or just replace , at release date 2002 definitely due for a replacement new psu
Mar 14, 2017 | Dell Precision 650 PC Desktop
Motherboard GA H57 M USB3 (ver. 2) is not responding
Muhammad Shahid i will give link that may help you
manual
thanks
Apr 18, 2012 | Gigabyte GAH57MUSB3 Motherboard
PC doesn't boot up.
Use jumper to reset cmos. Test or replace cmos battery.Unplug evthing( HDD,CD,DVD,FLoppy) try to start barebone. Test voltage from power supply to motherboard. Try different ram. Good Luck.
Nov 21, 2009 | EliteGroup Lga 775 GF7100PVT-M3/MCP73T-M3...
Ram assurance
The schematic layout of the P5VDC-MX on the user manual shows that there are 4 DIMM banks, set as 2 X 2 rows, 2 DDR2 and 2 DDR.
The user manual explicity states:
I am running different frequency modules without any problems. With the info above provided by ASUS, it may be possible that a fix could be available with a BIOS update. Otherwise, you can opt to use a lower capacity RAM along with your 1GB Corsair.
Hope this helps.
Jun 24, 2009 | ASUS P5VDC-MX Motherboard
No power to board
the processor may be fried not allowing it to power up , also if the processor fan is burnt out it won't start up either , also if any hardware is has failed and is crossing over it won't start
Jul 03, 2008 | Gateway (4000811) Motherboard
Asrock P4i65G Motherboard
If the CPU is dead the problems can be
  1. no power
  2. no fans etc or
  3. power, no beeps (errors)
If the Ram is not compatible it would be constant beeping.
With the board in, and power supply 20pin + 4pin Pent 4 power attached,(#2 and #7 of motherboard layout) remove power cord from power supply.
CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes
system setup information such as system password, date, time, and system
setup parameters. To clear and reset the system parameters to default setup,
please turn off the computer and unplug the power cord from the power
supply. After waiting for 15 seconds, use a jumper cap to short 2 pins on
CLRCMOS0 for 5 seconds. Remove the jumper. Remove heatsink and fan from CPU. disconnect cpu and reseat it. Re-install heatsink and fan. Plug in the power cord. Try to boot up. If it still does not boot and (no power, no fans etc.) problem would then be cpu is fried.
Jun 02, 2008 | Computers & Internet
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Intel D915GAV Motherboard Logo
153 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
