Hey when we turn on our dryer we get a burning smell and the drum doesnt turn, any ideas? we think the engine might have burnt out? we think its a very old model - kenmore ultra fabric care model 97590120 75901. Can it be saved?!
  • 3,037 Answers
Either something is binding the drum, or the motor has failed. Can you turn the drum by hand? If you can, then most likely the motor has failed, if you can't turn it by hand, then the drum is stuck and the motor just isn't able to turn it until you find whatever is binding the drum. You might have to remove the back panel to get in to see what might be causing the problem if it is binding.
Let me know what you find with this.
Benjamin
Posted on Feb 06, 2010
I was drying my tennis shoes in a pillow case. The shoes pillow case and 3 towels were in the dryer, I had a smell like belt burning turned it off immediately. LG Stackable Dryer.
I'd think unlikely to be belt, as that is only a drive connection. Remove back panel and take a look at the pulley. It might be the casting off center
Jan 11, 2018 | LG Dryers
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
Benjamin
Feb 06, 2010 | Kenmore 62602 Electric Dryer
Dryer makes a high pitch squeal and when you open the door it has a burnt smell.
roller/supports bad or idler pully sticking or drum ball support depending on model the burn smell odd can be caused by dragging during operation
Aug 20, 2009 | Whirlpool LER4634J Electric Dryer
Maytag dryer, LDG9334, won't start to rotate, burning smell
Hello Friend, From my experience, it sounds like the motor is tired and getting ready to fail. Only option is to replace. Happy to help, Tim.
Jul 11, 2009 | Dryers
A STRANGE SMELL WHEN DRYING..
sounds like brushes they can cause a burning smell......as for clothes smell after drying the fan in the heater could be dirty but generally that would mean the heater will not work
Mar 18, 2009 | Hotpoint Aquarius WD63 Front Load...
Motor smells on model lde7314ace
If the motor smell burnt it is going to burn up soon. Unfortunatly it is time to replace the motor if it is worth it. You may consider a new one. Once the motor goes you can guarante that something else will follow.
Jan 08, 2009 | Maytag PYE2300AY Electric Dryer
Burning smell and loose drum
If it is really noisey when it spins then this can only mean one thing.... the drum bearing are shot, its a complete strip down job, not an easy job for a beginer. Sorry
Dec 23, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Dryer not working all the time
99% of the time , a buzzing motor means the motor is almost burned up. Especially when you can smell it. A burnt motor calls for more current due to the laws of electricity and this overheats the motor windings and this is what you smell. If you are lucky, one other thing can cause a motor to buzz. Something is binding somewhere and the motor is not strong enough to turn the shaft. You would smell this also, but if you can find what is binding it and remove it, then you should be ok if you have not used it too much with it smelling. Look for a sock or wash rag tangled inside the dryer between the drum and the inner walls. This extra "drag" would cause the symptoms you are seeing, but something tells me that you have a burned up motor.
Mar 03, 2008 | Dryers
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
