Question about iiyama PROLITE E2200WS WIDESCREEN LCD 22" Monitor
How do I lighten my iiyama e2200ws prolite screen. It's dark at the top and lighter at the bottom
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: Iiyama Prolite 434S monitor is too dark
Dim or dark display can be caused by a faulty inverter board or faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp, the CCFL lamp is a miniture fluro tube and these dim with age.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Posted on Sep 28, 2009
How do you remove the plastic back from prolite e2200ws I have removed the 5 screws but moulding still does not wish to move.d
These are held together with plastic tabs. You will need to start in one corner and gently pry the case apart. GENTLY is the key. Most often, the front piece has the tab that fits into a little slot on the back of the case, so when you pry it off, you will actually be using a motion that bends the front of the bezel a little toward the center of the screen and pushes the bottom outward. Work your way around the screen.
Nov 09, 2011 | iiyama PROLITE E2200WS WIDESCREEN LCD 22"...
Iiyama prolite e1902wsv white screen , no picture
From time to time, I've the same white screen problem with my IIYAMA E1902WSV.
I can resolve that issue with a reset to factory settings.
1- Turn ON power (blue led)
2- Push on the MENU button and keep the button pushed while
pulling out the power cord.
3- Plug the power cord back while keeping the MENU button
pushed.
You should see the picture again.
Oct 18, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
How do I alter the definiton of the monitor?Illyama 2209hd.
I am assuming you mean the screen resolution.
It depends on what operating system you are running, but I will assume it's Windows.
You need to go to Control Panel (Start>Control Panel) and double click Display.
Select the Settings tab and then you will see a slider bar under Screen Resolution. Move the slider to your Monitor's optimum resolution setting and click Apply
Apr 09, 2010 | iiyama PROLITE E2200WS WIDESCREEN LCD 22"...
Iiyama prolite e430t remote frequency
my remot is loss.i whant to know that is my remot frequncy? my lcd modal is prolite e430t.
Feb 14, 2010 | iiyama ProLite E430T 17 in. LCD Television
www.lcdparts.net
Sep 28, 2009 | iiyama ProLite E434S 17" LCD Monitor
When i turn on my computer my screen gets after 1 sec dark and stays that way i can see my windows but its dark and the problem is not the adjustment of the monitor when i'm going into sleep mode and go...
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 19, 2009 | iiyama PROLITE E2200WS WIDESCREEN LCD 22"...
iiyama PROLITE E2200WS WIDESCREEN LCD  22" Monitor Logo
81 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Ed Mac
steve morris
steve morris
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
