My sony vaio pcv-RX514 has maximum allowable RAM of 1GB in 2 slots (ie max of 512MB in each slot). I want it to go faster, so I put 1 GB RAM in each slot. When I powered it up an alarm sounded and the computer would not boot. So the questios is: 1. will putting above the max RAM for my pc boost its speed, or will it just not recognise it? 2. How can I find this out if an alarm sounds and it won't power up if I put 2GB ram in it?
  • portlandston Feb 06, 2010
    I have fixed my new RAM in nice and tightly, so it is not loose fitting that is the problem.
    alternatively is there any other way to boost the speed of my pc?
    thanks!
  • 4,281 Answers
Your bios doesn;t support 2Gb RAM so it gives sound beep.
Make sure you fixed ram properly still you get beep sound then it not recognized in bios so you can't use 2 Gb ram on your laptop motherboard because it doesn't support it.
But before that also make sure both 1 Gb ram frequency speed and company are same it those different then you get that sound beep too.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Feb 06, 2010
  • Yes remove all temp files from computer
    Go to start->run type in run "%tmp%" then press enter in then delete all temp files.
    Then type in run "prefetch" then press enter then remove all prefetch files.
    Type in run "chkdsk /r" then press ok then restart computer then it fix error on computer.
    Also scan your computer with updated antivirus.
    You can increase virtual memory too.
    For that right click on my computer then click on property then advanced.Then performance->settings.->advanced.
    Then click on change and custome size set intial size to max size.
    Then apply and ok.
    Then your computer is speedup more.
    thanks for using FixYa.
  • 6,487 Answers
The answer for the first question is since your computer only supports a maximum of 1 GB RAM putting there 2 GIG of RAM will cause some problem on your system that;s why you heard a beeping sound and computer wont boot definitely. The system only support up to 1 GB of RAM so putting there 2 GB will cause some error on your system so when you power it on the system will try to read the 2 GB of RAM and that will create the beeping sound and it will cause further damage, Yes increasing the RAM of a computer will make it fast but just make sure you just put the maximum RAM adn don't exceed from it to avoid problem on the computer.
214-Dimm Config Warning
Just had same problem. Found a solution:
I have an old HP Compaq dc5000MT. It has 4 RAM slots
Here's what DIDN'T work:
1gb + 1gb + 512mb + 512mb
1gb + 512mb + 512mb + 1gb
512mb + 1gb + 1gb + 512mb
Here's what DID work:
1gb + 512mb + 1gb + 512mb
I'm sure that:
512mb + 1gb + 512mb + 1gb would probably work as well.
From my guess they're are 2 "channels" (slots 1&2 are channel 1, slots 3&4 are channel 2) and you have to keep the amount of RAM balanced on both slots and in the same order.
Another thing to note with the old XP OS. IT ONLY WORKS WITH 3GB or RAM. MAX. So 1 + 1 + 1 + 1 (4gb) WILL NOT WORK... PERIOD for XP. Vista, 7, 8 etc. allows you to use a ton more ram + readyboost. They need all the help they can get though since they are major resource hogs.
Aug 15, 2011 | HP Compaq d530c PC Desktop
Can i upgrade memory more than 1 gb , standard 512 mb. 3 slots available
Sony specs say:
  • Maximum Memory: 1024MB
  • Slots: 2 (2 banks of 1)
  • Standard Memory: 512MB removable
the answer is no.
If this answers your question, I'd appreciate 4 thumbs
Sep 14, 2010 | Sony VAIO PCV-W20 PC Desktop
What is the max ram speed my pc can take
According to some research, your desktop has 4 RAM slots available. The total maximum RAM your desktop can hold is 2GB (2048MB). Furthermore, each slot can hold a maximum of 1GB (1024) but cannot exceed the 2GB total.
This means you can theoretically install 2 x 1GB RAM DIMMS in 2 RAM slots or 4 x 512MB RAM DIMMS. Both will meet the desktops 2GB limitation.
The RAM specifications for your desktop are as follows:
RAM Limit: 2GB (2048MB) RAM Slot Type: SO-DIMM RAM Type: DDR1 (not DDR2 or DDR3) RAM Speed: PC3200/DDR400 ECC Type: Non-ECC
TIP: The RAM is DDR which means that while you can install them as singles (single-channel mode), the system will see a speed benefit from installing them as matched pairs (dual-channel mode).
Aug 14, 2010 | Sony VAIO VGC-RB34G PC Desktop
I have a intel 845GL motherboard with 1.7Ghz
2 x 184-pin DDR DIMM socket support up to 2 GB
recommended: 1GB x 2 DDR 333
http://www.svbinternational.com/motherboards/motherboard_845_chipset.htm
contact ur system admin/vendor for more details....
Nov 02, 2009 | Computers & Internet
Problem about ram
if the manual says that the board can support max of 1gb ram then each slot should support max of 512mb each. hope this helps
Aug 24, 2009 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Cant pick both RAM same time
hopefully you inserted two similiar 1 GB RAM memory devices by the same manufacturer into the right slots 1
you may have a board that:
- has four slots available (two + two)
- but supports only a maximum of 1GB (two similiar 512mb devices)
or
-supports only a max of 2 GB of the same kind and same manufacturer,
so inserting all u got and hoping the PC does the memory management might not work!
please see the mainboard manual (if u have one) or download it from the manufacturer's site.
Jun 18, 2009 | Computers & Internet
Ram questions
it has 1 gb ram. if you bay 1 gb it will be 2 gb.  if you buy 2 gb you can use together but it supportes only 2 gb. you can only see 2 gb.
May 27, 2009 | Sony VAIO VGC-RB53 PC Desktop
Adding RAM
If it has 4 slots and supports 2Gb max with 2 slots currently populated with 2 x 256mb chips you'll need to remove both those chips and install 4 x 512mb chips to reach the max of 2 Gb.
May 10, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
26 people viewed this question
k24674
jasbo
jasbo
