Question about Ovens
Gas oven - electric igniter - trips electric
After cleaning my oven this morning, I went to use it this afternoon - all was fine until after about 10 mins a sizzling noise was heard and then electric tripped.
The oven is no longer working - the igniter is working and it is still tripping electric sometimes
Any ideas please
  • 80 Answers
You have cleaner inside the glow coil marrets and it is probably causing a short circuit and tripping breaker
Posted on Feb 06, 2010
Electric wall double oven no power, no display, nothing works, breaker not tripped. What is the problem?
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Aug 04, 2014 | Ovens
There is no gas flow to one of the ovens igniters
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. I offer free advice bcuz God is so good!
GAS OVENS
Jan 28, 2014 | Viking 30" Professional Select Built-in...
Hi, my Blanco freestanding electric oven-FD9045WX-(gas cooktop) went out with a flash & a bang. The fan element was in pieces and the thermostat totally fried. The clock/timer does not go nor do the sparks...
Check for power at the supply terminals, follow it up to the high temp cutout > timer > multifunction switch > thermostat > element
Careful, don't electrocute yourself!
Oct 13, 2013 | Ovens
Electric range/oven switched from bake to self-clean without my help!
Good Afternoon Mr Oliver!
Often, if Whirlpool oven starts to do things on its own.. the touchpad might be failing or faulty. Keys fail and short, meaning they think they're being pressed when they actually aren't. Do you have the model number of you oven?
May 17, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Diplomat adp 0511 grill has no gas or ignition
GAS OVENS
Jan 18, 2013 | Belling XOU592 / XOU593 Electric Double...
Electrolux EOU5330X Ultrafan Electric Double Oven -
Sounds to me like the lower element shorted and tripped the breaker as it burned out. If you're handy at electrical troubleshooting that's where I'd start - comparing ohmmeter readings between the bad element and the one that works.
A wire short to the chassis would have a similar set of symptoms and be easier to find and fix.
Beyond that, you need a service tech.
Sep 03, 2017 | Electrolux EOU5330X Ultrafan Electric...
Hi Last night my oven just stopped working while I was baking. All the lights and clock went off and oven/broil controls are inoperable. The burners (and the electric ignition) continue to work fine. I...
You have a bad EOC electronic oven control unit, They are readily available from any parts house. They do not have instruction but are not difficult as it is just a few screws and swap out wire for wire. It may be a good idea to buy it from a vendor that allows returns of electrical items. Many do not allow returned electrical items. Please rate my answer and any comments are welcomed at least good ones:) Good Luck, Mastatech.
Aug 25, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My gas oven is not working-just used this afternoon for bread and chicken-it was fine-broiler and burners work ok
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 29, 2010 | GE Ovens
My Jenn-air oven won't turn on. It's model number
My Jenn Air 1995 wall oven was working fine until one day the oven and the oven gas burner did not turn ON. I had electricty (make sure you did not trip a breaker) since my front panel LCD and clock was OK. I had a good gas supply.
My oven is an "pilot-less" oven, it uses an electric igniter. Although the "ignitor" was "glowing red hot", the problem is that the gas valve depend on a certain amount of current. If you have a 120V house system, I think the valve needs 3.3 to 3.6 amps to turn on. The current flows through the igniter and then through the valve, as in a same path, like water. So you need an AMP meter to check proper current flow. I read 2.4 amps. I replaced the "glowing red hot" igniter with a new one, Vo"la it was fixed.
Bottom line if you have the oven plugged in OK and you see some life (clock), and you have the gas turned on, most likely the igniter is bad. Second choice would be the oven's thermostat (the temp knob that you turn, say to 350F), or it could be the gas valve.
All three are in same current circuit. The igniter gets the most abuse so I would start there first -good luck!
Sep 24, 2009 | Jenn-Air Ovens
Frigidaire Gas Range with Convection--fan does not turn on
The convection fan is wired through the door switch make sure your door switch is o.k. before replacing the board or the fan. Please have a local service tech check unit if you have to get into any electical checks. good luck
Dec 02, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
132 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
