Question about ZT Group ZT Reliant 823XI38 Desktop PC
The device is not setting up correctly (Code 1)
There is a ? marks present beside the Controller Simple of Comunications PCI.
I reinstall the driver again and I receive this message:
It can`t install this hardware.
Provider of the controller is unknown.
  • Carlls Feb 21, 2008
    How do i to download the specific system board drivers from
    the manufacturer´s website ?
    I don`t find it.
    Thanks for your help!!!
    Best Regards,
    Carlos Camacho.
Find the drivers for ZT Reliant
http://www.ztsystems.com/Default.aspx?tabid=866
Posted on Apr 21, 2009
    Problem Solver:
  • 9 Answers
Have you tried using windows update to search for a driver? Open the driver, then goto update driver and when it asks you the source check the box for windows update. Try that and see if it finds anything.
If it doesn't, you may need to download your specific system board drivers from the manufacturer's website.
Posted on Feb 21, 2008
Medion akoya notebook
Yellow mark stands for no/ improper drivers installed for those devices, check drivers for your system model and install.
Nov 08, 2012 | Medion Computers & Internet
In my computer -- properties-- hardware -- device manager -- PCI SIMPLE COMMUNICATION CONTROLLER IS SHOWING QUESTION MARK- DRIVER IS MISSING. MECHINE IS COMPAQ
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps don
Mar 09, 2011 | Compaq Computers & Internet
PCI simple comunications controller?
PCI simple comunications controller most probably means your "modem" drivers are not properly or not drivers installed.
Nov 02, 2010 | ASUS Computers & Internet
I need drivers for PCI Simple Communication Controller for a older computer running xp
download 50000 pc drivers for xp from torrentz/mininova make sure u have either bitlord or utorrent installed on ure system 1st when download is done move folder from in downloads to your desktop now open up device manager goto the pci device needing driver should have yellow question mark at it and tell the pc to search your desktop and it should hopefully find it in the folder when done delete folder and make sure your not running utorrent/bitlord as you will be shareing this file with others
Oct 09, 2009 | Computers & Internet
PCI Slot 1 (PCI bus 1, device 10, function 0)
Hi there,looks like your devices need updates to function correctly,
from devices manager,
select the device with the yellow question,
right click and click on update
even if you have no disk or internet
let the wizard find the drivers automatically
should be preinstalled with your OS XP
go thru your list and update any other question marks in yellow.
Should be able to update the network device on this system and then connect to the internet to finish anything else
heres the link for the Chaintech motherboards
http://www.download-device-drivers.com/Chaintech.php
Hope this helps,Cheers Misterdj
Jun 19, 2009 | Chaintech 9LIF7 i845G Motherboard
Device manager shows a big question mark on multimedia audio controller and PCI simple communications controller, dont know manufacturer to find correct driver, let me know how to find manufacturer of
The reason for these 2 big question marks is that Windows device drivers for the sound card & modem are not installed.
If you don't have the drivers for these 2 cards, let me now the make & model, & I can find them for you.
Apr 12, 2009 | Computers & Internet
Motherboard Simple PCI Communications Driver Code 28 for modem
Hello, Mike.
In case you still need this:
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware.
Hope this helps.
Mar 29, 2009 | Gigabyte GA-7VA Motherboard
PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Dec 07, 2007 | Gigabyte GA-7VT600 1394 Motherboard
ZT Group ZT Reliant 823XI38 Desktop PC  Logo
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
