Question about Lexmark C533DN InkJet Printer
Where is tray 1 located? - Lexmark C533DN InkJet Printer
    Genius:
  • 1,011 Answers
Most Lexmark printers have two input sources. The Manual Feed Tree, located at the top back of the printer across the top of the printer.
And Tray 1. Tray 1 is located under the Paper Exit Tray in the front bottom of the printer.
You lift up the paper exit tray to reach the Tray 1 to change the paper size guides. It comes set up for 8.5 X 11 (Letter Size) paper.
Don
Posted on Feb 06, 2010
Error CO202 Bizhub
C 0202 - 1 st tray lift up failured.
Remove the 1 st tray,in the right side located 1 screw and in copier is a paper when blocated the tray lift gear.Remove the misfed paper and push in the tray ,open and closed the right door and the copier must be ready.
C 0204 - 2nd tray
C 0206 - 3 rd tray
C 0208 - 4th tray
C 0211 - bypass tray
Good luck.
Feb 14, 2013 | Konica Minolta PRINTING - Bizhub-250...
Tip
PROBLEM - OUT OF PAPER
If many people are waiting for printouts, and nothing is actually being printed, the printer may be out of paper; the printer will indicate this on its display. To load paper into the N4525 printer, simply pull out the tray #1 or #2 located at the bottom of the printer in the front, and put the paper in the bin. Put the tray back into the printer. To load paper into the N24 printer, locate the tray in the front of the printer. <br />Pull the tray out, and locate the bin indicated by the large arrow in the lower left-hand corner. This is the side where you put the paper. Then, push tray 4 back in to the printer<br />.Make sure you put the paper on the correct side of the tray. This is the most common error. There are usually diagrams on the inside of the trays indicating how to put in the paper.
on Jan 06, 2011 | Office Equipment & Supplies
Where is located paper tray number 1 and paper tray number 2?
Tray 1 paper is the major tray located down the base, while tray two you have to open the door of the printer.
May 10, 2012 | HP LaserJet P4015n Monochrome Laser...
My aficio 2035e shows sc 329 and sc 322. what does this mean?
  1. Remove paper from all output trays. Depending upon the options fitted to your device, the output trays are:
  2. Locate the gray cables that are connected between finisher and main unit. Check that they are secure, and that the cables are in good condition.
  3. Switch off the device at the red power switch.
Dec 16, 2010 | Office Equipment & Supplies
How to open tray when it don't want to open
You can manually eject the tray, you have to take the faceplate off to do this, but here is the instructions:
http://www.llamma.com/xbox360/repair/manual_eject_xbox_360_dvd.htm
Aug 11, 2009 | Microsoft Xbox 360 Console
Paperjam tray 1 error code 201.52
If you remove tray 1, is there a jam? When the printer is starting to print, does it sound like it is trying to pick up paper from the tray a few times, and then changes to the jam error? If so, then the pickup rollers are worn. You can confirm this by removing tray 1 and feeling the rollers which are located in the top of the tray in the front. If they feel smooth, then they need to be replaced.
Feb 22, 2009 | IBM Infoprint 1572n Laser Printer
Printer won't print
60.2
printer error
The tray 2 lifter-motor is not functioning. 1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
This is straight out of the manual.
Tray 2 lifter-drive assembly
Remove the following assemblies:
● Rear accessory cover. See Accessory covers and the tray 2 extension door.
● Top cover. See Top cover.
● Right-side cover. See Right-side cover.
● Formatter cover. See Formatter cover
● Formatter. See Formatter assembly
● Paper-pickup drive assembly. See Paper-pickup drive assembly.
2 Unplug the tray 2 lifter-drive assembly connector from the dc controller PCA (location J93) and
the two flat cables (callout 1, locations J80, J81). Unweave the wire-harness from the cable
guide (callout 2).
NOTE You might have to remove additional wire-harnesses from the cable guide to gain
access to the lifter-drive assembly wire-harness.
Figure 6-51 Tray 2 lifter-drive assembly (1 of 3)
Main assemblies 227
Unhook the tension spring (callout 3) at the lifter-drive assembly, remove one screw (callout 4),
and then slide the support plate (callout 5) out of the printer.
Figure 6-52 Tray 2 lifter-drive assembly (2 of 3)
228 6
Rotate the top of the lifter-drive assembly away from the printer to remove it from the printer.
NOTE You might have to remove some cable guides to easily remove the lifter-driver
assembly.
Figure 6-53 Tray 2 lifter-drive assembly (3 of 3)
Main assemblies
unfortunately i couldn't paste the pictures to help you.
Assembly is the exact reverse of removal, Good Luck!
Nov 20, 2008 | HP LaserJet 4250n Printer
My kyocera printer has two input trays with different stationary. The problem occurs when tray 1 runs out of paper, it defaults to tray 2, thus using the wrong stationary. How can i disable TRAY 1 from...
go to installed printer location, right click on your installed printer, click on properties you will find the paper source there and change it accordingly.
Oct 21, 2008 | Kyocera Office Equipment & Supplies
Error 13.20.00
There is a paper feed sensor located behind Tray 1 where the tension spring gets knocked loose, therefore the sensor arm is still blocking the sensor. You have to remove all covers and the Tray 1 Assembly and re-install the spring which goes into a slot on the plastic frame.
Apr 11, 2008 | HP LaserJet 4350 Printer
Repair
if it won't open, turn off the console and remove the faceplate and try to eject the button. if it still won't open get a paper clip and straighten it out. you need to locate a small hole that exactly fits a straightened paper clip. it's located just below the silver lining of the disc tray about one and a half (1 1/2") inch from the left side of the disc tray. insert the paper clip into that hole and it should pop up the disc tray enough for you to be able to pull the disc tray all the way.
if it doesn't work there are still 2 more small holes that you can locate. the 2nd one is just beside the first hole and the 3rd one is just under the second X on the XBOX 360 text on the disc tray. try those two holes if the first hole doesn't work.
Jan 17, 2008 | Microsoft Xbox 360 Console
Lexmark C533DN InkJet Printer Logo
120 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
