Question about HP PSC 2210 All-In-One InkJet Printer
All the buttons are blinking and can't print document.
  • 4,041 Answers
Hi
I think it is your cartages need a clean any where I found a reset for you but before you try this reset I would go to the link I put for you to look at it tell you how to clean them.
Click this Link= http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00058182
Step 1: Semi-full reset
Remove both the cartridges and then perform the reset.
Perform a semi-full reset on your PSC 2200 by holding the button
combination given below, while plugging in the power cord.
CAUTION: A semi-full reset will reset or clear the following
information:
* Return the user settings to the factory defaults.
* Delete language and country settings on some models.
* Fax logs.
* Fax headers.
* Fax speed dial information.
Press and hold "#" and "6" buttons while on the front panel keypad,
Now insert the cartridges back.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 06, 2010
Hp d24610 on/off button is blinking not printing
Check out http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00866324&product=2510767
try changing your cartrdige. Refilled cartridge may not work. Blinking power button usually indicates out of ink.
Nov 01, 2010 | HP Deskjet 2460 InkJet Printer
Hpdeskjet problem
A light blinking under the cancel button usually indicates a problem with the color cartridge.
Go to this page for instructions on resolving that issue - about halfway down the page is a picture of your printer control panel with both the left and right light blinking. The section explains that it's to help if "One or both print cartridge status lights are on and blinking."
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01368924&cc=us&lc=en&dlc=en&product=3374277
Jun 04, 2010 | HP DeskJet D2560 InkJet Printer
The light on the left of my printer is blinking
hi, sometimes this results to documents that are pending and didnt finish to print. try to cancel the documents on the print tasks and try to unplug the printer then plug it again to get rid of the light and start printing again. hope this helps
Feb 19, 2010 | HP DeskJet 970cxi InkJet Printer
Paper feed button keeps blinking; documents won't print
which buttons keeps blinking? have you checked your cartridges. you could be out of ink
Jul 13, 2009 | Lexmark Z2420 Printer
Two red lights below buttons are continuously blinking & printer does not printing document
Hi I mhel I have a solution for your problem, you just have to download a program called SSC SERVICE UTILITY and install it in your computer. this is a free software . Just email me if this works and solve your problem
mhel
mijamhel@yahoo.com
mhel_services@yahoo.com
May 31, 2009 | HP Office Equipment & Supplies
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
Document is not printing
Press the feed button. If that doesn't work, turn the printer off, wait a few seconds, and turn it back on again.
Feb 03, 2009 | HP DeskJet 932c InkJet Printer
Power button is blinking
unplug...take a long cafe or latte break..
come back..try again
Mar 03, 2008 | Lexmark Color JetPrinter Z23 InkJet
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
106 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
