Need to know how to disassemble dryer to access orifice for propane conversion
    Top Expert:
  • Washing Mach... Master
  • 76,846 Answers
  • yadayada
    yadayada Feb 06, 2010
    PULL THE FRONT OFF THE MACHINE BY OPENING THE DOOR AND REMOVING SCREWS THAT HOLD THE TOP DOWN AND THE SCREWS THAT HOLD THE FRONT IN PLACE. CHECK AND SEE IF THE TENSION PULLEY IS WORN AND LOOSE ON ITS SHAFT. CHECK AND SEE IF THE DRUM SUPPORT ROLLERS ARE LOOSE ON THE SHAFTS/AXLES. IF THEY ARE THE PULLEY AND/OR ROLLERS MUST BE REPLACED. THE AXLES SELDOM WEAR OUT SO YOU PROBABLY DO NOT NEED TO REPLACE THEM-BUT DO CHECK THEM.
    DRAPE THE BELT OVER THE DRUM-LIFTING THE FRONT OF THE DRUM UP OFF THE ROLLERS AND SLIDING THE BELT INTO PLACE. HOOK THE BELT OVER THE MOTOR SHAFT PULLEY BY FEEDING IT BETWEEN THE IDLER PULLEY AND THE IDLER PULLEY SPRING TENSIONER. THE IDLER PULLEY IS COMPLETELY ASSEMBLED AND HOOKED INTO THE BOTTOM FLOOR OF THE DRYER WHEN YOU THREAD THE BELT (DOUBLED)THROUGH THE IDLER ASSY ONTO THE MOTOR PULLEY. BELTS LAST SEVERAL YEARS AND FAIL DUE TO AGE OR BAD ROLLERS/PULLEY. IF DUE TO AGE YOU WILL SEE MANY SMALL AGE CRACKS IN THE BELT. IF IT LOOKS LIKE THE NEW BELT-WITH NO CRACKS-IT HAS NOT FAILED DUE TO AGE.
    BELOW IS SHOWN THE URL FOR A WEBSITE THAT SHOWS SEVERAL TYPES OF DRYERS IN CASE YOUR DRYER IS NOT THE TYPE I THINK IT IS. YOU MAY FIND THAT WEBSITE USEFUL.
    OPEN YOUR DOOR AND GET THE COMPLETE MODEL No. OFF THE NAMEPLATE TO GO ANY FURTHER
How do you revert a Kenmore Elite He5 gas dryer from propane to natural gas. Is it just changing out the orifice?
a little more than the orifice needs to be changed the pressure regulator and on some the whole gas valve body
Sep 24, 2016 | Kenmore Dryers
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
Need to change from LP to propane. How do I get access
Gas to Propane requires a Propane Certified technician. These technicians are provided by the company that provides Propane that they will be using.
You may need to get a Propane conversion kit, for technician from the Propane company to install.
You can certainly double check on this...Hope this helps.
May 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Do I need a part to convert my Maytag gas dryer/washer combo back from propane to Natural Gas?
Yes you can, but whether you should is another matter. I purchased a new dryer and needed it to be propane ready...you need to get the proper orifice (which lets the gas in to the burners) changed out. Natural gas orifice has a larger hole than a propane orifice. In addition, the regulator must be modified. It may involve flipping an insert under the cap (typical of stoves) or it may require conversion parts packed in the conversion kit (order one specific to your drier). This regulator is part of the piping within the back of the drier.
Incidentally, conversion orifice(s) should be included with the drier and screwed to the body in a clip. When you change it over and label the equipment as converted to propane, put the old natural gas orifice in the clip and screw it back onto the body. Put the instructions in a paper envelope and tape to the outside of the body of the drier.
Apr 27, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Whirlpool duet gas to propane conversion
no you definately need to change orfices from gas(line) to propane, call your gas supplier for a conversion kit or go to an appliance parts store and they will help you on this on this matter,don't try to start this unit after change-over if the orfice isn't right, i tried it and found out tooooooooo late
Apr 04, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Propane to nat. gas dryer
Good day,
Yes. Two reasons. The orifice that the gas comes out is a different size, and the regulator that determines gas pressure is disabled when using Propane, since propane has the regulator on the tank.
See here.
http://fixitnow.com/wp/2009/03/13/converting-a-gas-dryer-from-natural-gas-to-propane/
If you are not 100% sure what your doing, call a qualified company to perform the conversion. Isn't worth the gamble.
Propane is, unlike natural gas, heavier than air. It can pool in a low spot then ............
Dec 25, 2009 | Whirlpool GGW9200L Gas Dryer
Older Frigidare Elite Dryer conversion
You'll have to contact Frigidaire to see if a conversion kit is available. Normally, it's just an orifice replaced on the gas valve.
Feb 18, 2008 | Frigidaire GLGR341AS Gas Dryer
Washing Machines Logo
109 people viewed this question
Top Washing Machines Experts
