Question about Technics SA-DX940
Fan not running on reciever - Technics SA-DX940
    Problem Solver:
  • 4 Answers
The fan only runs when the volume control is turned up to a predetermined "high" power level.
Hope this helps.
Posted on Feb 10, 2010
  • 1 more comment
  • tasia0119 Aug 14, 2011
    my question is the overload comes on after you turn the voulem so high and the fan runs all the time is the fan suspose to blow in or out of the receiver
  • Bob Crawford Aug 14, 2011
    I don't remember, but probably out as that would expend the heat instead of drawing cool air into the cabinet to be heated with nowhere to go.
  • S Sigs
    S Sigs Jan 23, 2016
    It blows out (exhaust). The fan speed is also determined by the amount of power being used by the receiver (when the volume is higher it uses more power). If there is no source audio, turning the volume up will not make the fan turn on.
Fan in receiver not working can it be fixed. Receiver gets really hot.
open the reciever and clean the fan...the fan is dirty...it has accumulated dust....turn the reciever on and help the fan to turn by helping it turn bu use of your finger...do not oil the fan...
Oct 16, 2014 | Audio Players & Recorders
Fan is not working on the radiator
replace the relay for it if the fan motors work hot wired direct
Aug 19, 2010 | 1998 Ford Taurus
My hunter fan is not working. the remote has a new battery however it will not turn the fan on or off and it will not turn the light on or off. the chain on the fan will only work the light. the fan...
It sounds that fan use to work and lights and you did correct thing by changing battery. I've had this problem and it just needs the reciever replaced. Reciever is located at electrical connection in ceiling. Just buy a new universal wireless remote and reciever at any home depot. if dont fill safe doing this task should call an electician to do job or someone with electrical skills.
Aug 13, 2010 | Hunter Ceiling Fan Light Remote Control
Can you wire a97 jetta cooling fan to come on when the key is on?
yes ,run a feed from the ignition side of switch with a relay recieving this power ,other side of relay to earth then a heavy feed from a big fuse under bonnet one of 40 amps with other side running to fan using the existing earth on the fan.
Jun 21, 2009 | 1997 Volkswagen Jetta
F3 error code
Check the connection from the temp censor to the board. A break in the wire will cause the F3 and fan to run. Good luck.
Apr 11, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Fan runs all the time
The inside fan has to run all the time. It turns off it will not keep things cold. Not the fan outside in the air it shoulc cycle with the compressor.
Apr 01, 2009 | Beverage-Air MT17 Refrigerator Commercial
Hampton bay fan with remot problem
You can try the universal receiver. The white, black, and green wires are the house wires. The receiver must match to these on one side. The wires on the other side go to the fan/lights. It is possible that one of these has come loose. If you try the universal, make sure the dip switches are in the same positions on both.
Or,
Take the fan down, and remove the receiver completely, from house wires and fan. (Make sure the breaker is off first!) Then wire the fan directly to the house wires. The blue wire on the fan is for lights. Wire it with the black wire in the same wire nut.
I'm assuming you have a wall switch that powers the wires coming from the ceiling.
By the way, I have never seen anyone control two fans with lights with one receiver. Usually each fan has its on.
Feb 09, 2009 | Hampton Bay 52 In. Ant. Brass Redington...
Remote control problem
The remote "reciever" is seperate from the fan. It is black in color with 6 wires, one being the antenna. It is wired together inside the fan canopy. If you do not have the reciever then you will have to buy a new one. You can purchase just the reciever, but you will need your remote to match it with
Jan 16, 2009 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Cooling fan in reciever noise.
Its necessary to run cooling fan because Amplifiers in home theater system produce heat during its operation. If you shut down cooling fan, Amplifier ICs may be damaged due to over heat.
Aug 24, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Technics SA-DX940 Logo
276 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
