Question about Keurig B60 Coffee Maker
My Keurig B60 just stays flashing "NOT READY". I can turn it off, I can't get the menu... nothing. I unplug it and it comes back on the same way.
    Scholar:
  • 28 Answers
Try removing the water reservoir tank, the replacing it. Make sure the reservoir tank is seated properly. There seems to be a problem with this model with the water reservoirs not seating properly and causing the unit to stop working or shut off. Hope that helps! Best of luck...
Posted on Feb 07, 2010
Keurig B60 screen flashes "Not Ready," "Auto Set Off" and "Brew Temp." The machine also will not shut off. Unplugging it does nothing, nor does the reset sequence of button pushing. Is there anything else...
Lots of problems with the B60/65/70 units. There are some really good videos on you tube, but trust me, the process to fix is going to be a pain and cost ~$50. You should consider taking yours back for an exchange. There is a known problem with these models and it appears the retailers are being very generous on exchanges (check this out: http://babelniche.wordpress.com/2012/03/10/keurig-dumps-inventor-builds-millions-of-junk-coffee-makers/) .... Good luck
Nov 22, 2013 | Keurig Platinum B70 Coffee Maker
Keurig B60 will not stay on
Turn off Auto Start. see manual page 17 for indstructions.
Feb 23, 2012 | Keurig B60 Coffee Maker
Keurig B60 Flashing NOT Ready
Needs Priming as per page 17 in manual. Read this section.
Feb 01, 2012 | Keurig B60 Coffee Maker
My Keurig B60 does not run at all. The screen comes on and says: Not Ready and also says auto off set. The cup lights do not flash. I cannot get the menu to come on. Unplugging it and plugging it in...
Not sure if this will help, but I had the same problem over Xmas. This was posted 8 Jan, and I cut/pasted it here. Sounds complicated, but it's not. Just print it off instead of trying to remember it! I'd be interested to see if you had the same 'codes' as I, and if your machine had hot water when it ran... I have not done anything since that post...
Patient: Keurig B60
Symptom: "Not ready" light is on. Reservoir is filled and needles are clean, so problem is not user related.
Internet search yeilded some hope for another Keurig machine. While turned off, simultaneously press and release the small and med button, then menu three times. You get into a programming/diagostics menu. As you scroll (via the menu button) mine says Ready 602, Brew 265, Autooff 099, Set 007, Set/set 099, Descale 099, and Menu 000.
While at 000, press the med button but do not release. Press and release menu and immediately press small, then let go of small and med together. Pump runs and water is circulating, but is cold. Not sure if it should be cold (just a test routine, etc) or whether the heater is blown or something more troublesome.
Anyone have any ideas/experience with this information (I have no problem in ripping the machine apart if I have to. It can't be that complicated!).
Jan 31, 2010 | Keurig B60 Coffee Maker
Brew lit, but "not ready" lit solid "not flashing" fix
There are 4 steps to fix this:
1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
Aug 10, 2009 | Keurig B60 Coffee Maker
B60 just flashes not ready yet ,have unpluged and tried that small cup med. cup and menu thing nothing changed
There has to be water in it first off. See my solution on the B50 with a similar problem. Before the lights blink ready the top (K-Cup Holder)has to opened and closed. Then the lights should blink and it should say ready to brew. I wish I had included that in the previous solution on the B50.
Feb 22, 2009 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
880 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
