Question about Car Audio & Video
Does any one have wiring diagram for drivers side front door speaker that has factory amp on it? 1999 dodge quad cab
    Problem Solver:
  • 12 Answers
The best bet is to run wires fresh to bypass amp
Posted on Feb 09, 2010
My drivers side front speaker stopped working in my 2003 dodge ram pickup
remove the speaker from drivers side , put that speaker in passengers side , if works in passenger side then speaker is o.k and if not speaker is stuffed if working wiring problem in drivers door or from stereo head unit .
Mar 28, 2014 | Dodge Ram 1500 Cars & Trucks
1999 dodge truck speaker wire coler picture diagrame
2010 Dodge Ram 2500 Car Audio Installation Guide
Left Front Speaker Positive Wire (+): Gray/Violet
Left Front Speaker Negative Wire (-): Gray/Yellow
Right Front Speaker Positive Wire (+): Dark Green/Violet
Right Front Speaker Negative Wire (-): Dark Green/Yellow
Left Rear Speaker Positive Wire (+): Gray/Dark Green
Left Rear Speaker Negative Wire (-): Gray/Light Green
Right Rear Speaker Positive Wire (+): Dark Green/Gray
Right Rear Speaker Negative Wire (-): Dark Green/Light Green
Jun 29, 2012 | Cars & Trucks
I need a factory speaker and radio wiring diagram for a 2009 dodge 2500 quad cab truck
This is what my books show.
2009 Dodge Ram 2500 Car Radio Install Instructions
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Amp Trigger Wire: Dark Green/Red
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jun 12, 2012 | Cars & Trucks
My driver side rear door on my 2004 dodge ram 1500 quad cab wont lock or unlock with keyless entry or the door lock button. but i can manually lock and unlock the door and i was wondering how to fix it
Could be very simple. Remove inside door panel & check for disconnected wire to solenoid. If okay--check where wires enter the door for broken or corroded wire & repair.
Mar 10, 2011 | Dodge Ram 1500 Cars & Trucks
Will a Dodge Ram Quad Cab door fit a regular cab door?
Yes, it will. The front doors are the same.
Jan 20, 2011 | 1999 Dodge Ram
I have a 2002 dodge ram 1500 quad cab. the gauges
Check your fuses. This a common thing that can come up often if you have changed from stock stereo equipment to after market, or just because of old fuses.
Once you locate the fuse box, it should give you a diagram of which fuses go to the different lighting systems in your car. Replace them and the problem should be fixed.
If the problem is not fixed from that, then have your wiring checked throughout the truck.
Jul 16, 2010 | MTX Dodge Ram Quad Cab 2002-2003...
My 2003 dodge ram quad cab driver side window switches work however my front passengerside switches do not. I bought a new switch and it still didnt work. could it be a relay or fuse?
In a lot of trucks I have found a cut wire where the wires run from the door to the truck body in between the door hinges. Almost all the time its the wires on the driver side, cause there are so many wires pact in their. Its kind of a pane to get in between the door and the body to look at the wires.
Sep 03, 2009 | Dodge Ram 1500 Cars & Trucks
1999 2500 quad cab rear door won't open
Linkage has come off inside the door. You must remove the inner door panel and reattach or replace if broken.
Jan 03, 2009 | 1999 Dodge Ram 2500 4WD
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
