Question about Bernina Sewing Machines
I have a bernette 60 sewing machine and every few inches the under stitches are loose for several stitches then become normal again. RAM from Clifton Park NY
  • 106 Answers
SOURCE: machine will not stitch
It is either a top or bottom tension problem. Top tension speaks for itself. Most folks do not know that there is the facility on the bobbin case to alter the bottom tension. Your user manual will tell you how to do this. It is very difficult to describe how to do it you need diagrams or to be shown
Posted on Mar 26, 2008
safenude
  • 124 Answers
SOURCE: Loose stitch
Welcome to FixYa. I am the sewing machine expert that chose your issue to solve.
When everything seems to be working fine and an occasional stitch is loose.....now get ready.......here it is.......the needle!
It seems impossible, but the needle is the most neglected part of the machine. The one you are using could be slightly bent or have a slight burr that you won't see with the naked eye. Also, needles, especially in an embroidery machine (which work their buns off), are only good for about 8 hours of cumulative use. I would say that an embroidery needle should be retired after 3 or 4. They get dull like a razor blade which can cause enough drag to create a timing issue that's barely perceptible.
Welcome to FixYa! I am the sewing machine expert that chose to help you with your issue.
There are really only two things that can cause bottom (note: remember that problems with the bottom thread, almost always comes from the top and not the bobbin. Bobbins rarely need tension adjustments). These two things are:
  1. An area was missed when the machine was threaded (most machines have an arrow at each area on the thread path where the thread MUST run or the stitch on the bottom will be sloppy. Threading can be tricky and even the most experienced miss once in a while.
  2. The tension adjustment mechanism in the thread path. If the thread is not properly through this area, the thread on the bottom will be sloppy or if, threaded properly, and the tension is set too loose, the stitch will be sloppy. If the tension is set too tight, the bottom thread will be tight and pucker the fabric.
It is counter-intuitive that problems with the top tension cause problems with the bottom stitch but it sure will.
So try it and see if that helps.
Thanks for using FixYa.com
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further.
Posted on Jan 31, 2009
louislevel_2
  • 374 Answers
SOURCE: bobbin sewing loose
hi there,
there is a problem on tension adjustment and setting of stitch
try to learn on actual video how to set thread and sewing, log on www.youtube.com on search box type Husqvarna sewing machine
and theres a lot more tricks on sewing.have a nice day don't forget to rate me. thank's
Posted on Apr 22, 2009
bargainbox
  • 1388 Answers
SOURCE: my white sewing machine is skip stitching
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Posted on Aug 27, 2009
SOURCE: I have a Bernette 65
check the thread tension
check the needle to make sure it's the right one for the thread
to check the needle to if it's work with the thread
here's how to check
cut a 8 inch piece of the thread your going to use for the project, take the needle your going to use out of the machine or package, & insert the 6-8 inch thread into the eye of needle
& lift on side of the thread up to a 45 degree angle & if needle is the right size needle for the thread, it will side down the thread easily,,but if it hangs up you need a needle 1 size larger
Posted on Sep 25, 2010
Is it possible to get a bigger hoop size for the Bernina Bernette Deco 600?
here is a link for part for the machine, if the part you need is not on the link, you'll have to contact bernina website or a bernina dealer Bernina DECO 600 Parts
Mar 13, 2014 | Bernina Bernette Deco 600
My Bernina Bernette 65 has a problem with the thread bunching up every 10-15 stiches on the bottom. Some of the thread stitches on the bottom of the fabric are in a straight line, and then the thread will...
try a new needle--one that is for the fabric being sewed
then try to adjust the top thread tension again, if the stitches remain loose and the tension won't adjust then the tension knob needs to be checked to see if there is something wrong with it.
also check to make sure the bobbin is inserted correctly into the bobbin case, if the bobbin is not turned the right way in the bobbin case the sewing machine will not stitch correctly.
Aug 05, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
I have a Bernette 65 and when I sew, the stitch is loose and sometimes loopy on one side. The stitches are crooked on one side and the other side they are loose and the understitch is visible. What do I...
here's how to check
Sep 25, 2010 | Bernina BERNETTE 65 Mechanical Sewing...
Viking Designer 1 balleds / Birdnest / issues after repaired from Husk service center in midwest - replaced thread needle and adjusted tension .. freequilting and embroidery situations
birdsnest refers to a mess of thread on the underside of fabric when you start sewing (after a few stitches all looks good). if this is the case and it is happening during embroidery, switch off jump stitch thread cutting.
if it happens at the start of normal sewing, either hold your needle thread when you start sewing or make sure the needle thread is under the presser foot and held by the presser foot when you start sewing. this way you will have an inch or so of thread on top of your fabric which you can trim instead of a mess underneath.
if there is a mess underneath for more than first few stitches, either your check spring in the needle tension area is set incorrectly, or your needle tension is set too loose (adjustable in sevice menu by tech only) or there is foreign matter caught in tension assembly preventing proper tension.
scott
Jul 26, 2009 | Husqvarna Sewing Machines
Sewing Machine Stops
this sounds like its set for zippers check settings!
Dec 09, 2008 | Husqvarna Sewing Machines
Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
May 19, 2008 | Bernina Bernette Deco 600
Sewing Machines Logo
120 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
