Question about Whirlpool Duet GHW9150P Front Load Washer
The problem with front load washers is they don't use enough water to rinse the load or flush out the soap and dirty residue. I fixed my washer by increasing the amount of water in the fill cycle, and by taking off all the hoses inside the washer and cleaning them with bleach. Now my towels come out smelling like they should and in about 1 month's worth of laundry the hoses still look clean as when it was new. Another tip is to leave the door stand open after the last load. All the water does not drain after the rinse cycle so leaving the door open helps it to evaporate out.
  • 56 Answers
Cutting back on the soap is the biggest issue. following the soap cap is far too much
Posted on Feb 06, 2010
I am sick of my washer smelling all of the time. We have done all the things that others have stated to try. I think that there should be a recall on the Frigidaire front load washer. I am very sorry...
Maytag is not american anymore. You will have the same problems. Front load maintenence 101.
dont use natural or green detergents that are plant oil based. Use HE detergent only, powder is preferable. Leave the door open for 24 hours after the last wash load is done. mildew can not grow in the absence of moisture. Once a month run the washer empty with 2 cups of bleach on the hottest setting possible. If you dont do this from day 1, you may have to do it several times to get rid of the built up gunk.
last tip, and the most important. dont use too much detergent. HE washers use much less water than a regular washer. If you put a ton of soap in there, it will build up over time because your washer doesnt use enough water to rinse it out. If you start a load of laundry with no soap, but you see bubbles in the water, it means you have too much soap residue in your washer.
use good quality detergent. Save money by using less of it, not by using cheap detergent. Unless your clothes are really dirty, you can safely use half of the recommended amount.
Nov 21, 2010 | Frigidaire GLTF2940ES Front Load Washer
Soap
How much HE detergent is used can vary from household to household, depending on such factors as water softness level, soil level of clothing, load size, etc. Because excessive suds can cause build up in the machine, leading to decreased cleaning performance, odor and damage to parts, reduce the amount of detergent if sudsing occurs. How do you know when you have gotten all the soap out? Try extra rinse and make use of custom program to perform additional rinse.
Sep 09, 2007 | LG WM-2277HW Front Load Washer
My new dishwasher leaves a white residue on my pots. pans and stainless flatware. I have not changed soap. Could the water not be hot enough?
Check the incoming water quality. If water is hard and having calcium content this could happen. Use water softeners in the inlet water to the machine.
If dish washer salt compartment available fill with the special salt meant for dish washers.
Check rinse aid compartment and fill rinse aid. Or use two in one soap tablet.
Sep 19, 2010 | Whirlpool Dishwashers
Residue on clothes
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Hi We Have a ge front load washer and dryer and it seems that our clothes smell musty at times. I've tried leaving the door open on the washer when not in use. Could there be another prooblem??
Try using vinegar, baking soda, or bleach in an empty load to counteract any residues left in onboard water. Also check for debris stuck in door baffle(rubber sleeve between door and tub).
Nov 17, 2009 | GE WSXH208A Front Load Washer
Kenmore 80 series washer leaves soap residue on clothes no matter
After speaking with someone with trouble shooting experience in these matters, I now believe the problem lies NOT with the washer but with a bad batch of laundry detergent which fails to dissolve properly in the water.
Mar 12, 2009 | Kenmore 22422 Top Load Washer
Dark dirty spots on some clothing items appears on every load.
what you are seeing is suds getting back onto the clothes. make sure you are using HE type soap and not using too much of it.
if you are seeing suds inside the unit, when it is running, then it will "re-deposite" dirty soap residues back onto the clothes.
you need to run a rinse and spin cycle or even a heavy duty cycle with hot water to rinse out any soap that is left in the unit.
not a major problem, just use it differently and it will be ok.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Smell from washer sounds like water still in washer
neptune washers are the only front loaders that have a counter balance system and they do have water in them to do this. water sound is normal.
when you are having an odor, it is from using the wrong soap or too much of the right soap.
you need to be using "HE" type soap and dont use too much. what you are smelling is soap residues that are not getting rinsed out from the unit.
they do make a special cleaning tablet called "affresh" and it is designed to clean out these residues.
also your washer will have a " brush" type device around the front of outertub where the inner tub meet.
it is between the tubs and will collect debris and can look nasty when dirty.
clean all you can see and then try to run 1 cup bleach thru unit if you cant find affresh tablets. at lowes or sears.
then make sure you use HE type soap next time to prevent build up and odors.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet Front Load Washer WFW8300SW00 Problem: I am using HE detergent and using less than the recommended amount; however, there is always a small ***** of suds sitting on the seal when I open the...
If you have a water softener or very soft water, soap will suds up more than if your water is normal or hard, so you'll need to use less than recommended. Obviously soap breaks down the dirt, but the dirt also breaks down the soap, so if your clothes are not very dirty to start with, you'll need less soap than if they were more dirty. Soap can also be stored in laundry like towels and cleaning rags and when combined with the laundry soap will suds more. You can try raising the leveling legs in the front to tip the washer back. This will help the water drain back into the tub instead of pooling on the boot. You can also try using the 'extra rinse' option. Keep cutting back on how much soap you use until your laundry is not as clean as it should be. You might be surprised how little soap you can use!
Jul 21, 2008 | Whirlpool Washing Machines
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
208 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
