The washer is a roper model numb.er ras7133kq0. When it gets to spin cycle it drains but the drum won't spin. It agitates fine to, any ideas?
  • 11,896 Answers
This may be a bad clutch. Can you see it move at all when in the spin cycle? It should be moving to engage the tub for spin cycle. Different then the agitate cycle.
This washer is designed to drain without spinning. Are you sure it is not draining? I have seen a few of these washers get stuck in neutral drain and not spin but they always drain. Does the motor run or just hum?
It is also very possible that you have a bad lid switch. You can check it for continuity with an ohmmeter to see if you get any type of reading when in the spin cycle.
Posted on Feb 06, 2010
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
My washer will spin but very slowly. Motor and shaft spins out of washer.
Your problem sounds like the drum/tub drive clutch is worn. Especially if the motor operates fine and attempts to spin the tub. This model is a direct drive unit, no belts, so if the motor operates during the spin and drain cycles but the tub is barely moving, only two problems can cause this, bad clutch (which is engaged only during the spin cycles) or worn drive coupling on the motor. If the coupling were a problem, though, you would also notice sluggish or erratic agitation during the wash cycle.
Hope this helps
kcomp1863
Jan 04, 2011 | Roper RAS6233KQ Top Load Washer
Drum won't spin, drains ok and agitator works fine
http://www.pcappliancerepair.com/model-display.php This site shows your lid switch. Just enter your model number. The lid switch is the usual suspect for your symptom.
May 09, 2009 | Washing Machines
Roper RAL6245AW0 Washer Won't Drain or Spin
We have a Kelvinator Washing Machine that just won't drain , but fills , agitates , & spins just fine. What shall we do?
Oct 13, 2008 | Washing Machines
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Washer won't drain
Mustache, sounds like you have a broken lid switch. No spin, no drain usually a sign of this. Check to see if the actuator is making the lid switch, or the switch itself is bad. Part number for the switch is 8318084. Catriver, post back.
Jul 30, 2006 | Roper RAX4233PQ Top Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
