Question about Sta Rite Maxi Therm 400k Btu Propane Heater
When i turn on sta rite spa heater , i can hear it start up , and run for about 20 seconds , then shuts off , EO5 appears on control board with red light next to service heater , whats wrong ?
  • 990 Answers
This is an ignition falure code. What you hear is the fan starting not the heater fireing. This can be a number of things and sorry to say but you should have a repairman out to look at the heater. The gambet runs from very frail parts to just plain dangerous and should have a qualified person check it out.
Posted on Feb 06, 2010
Get several codes , when i turn it on all the lights come on and display has a 888, then a 180. all goes off, receive a code sf 1, then an r4
Check your stack flu sensor. Sensor can not be jumped. As soon as the heater fires hold down the pool or spa button until the stack temp appears. At 500 degrees the heater will shut off giving a code. The heater should not restart. I would also check for wire damage based on the description of your issue and the board restarting on it own. You may also have damage to the "user interface board" , hard to say with out on site trouble shooting.
Jun 04, 2017 | Sta Rite Sta-Rite Max-E-Therm High...
My Sta-Rite poll heater doesn't work. The heater comes on when every time I restore power to the unit, the membrain buttons only work to change the temp. ont to shut off the unit, I use the service...
This issue sounds tricky. I recommend you callthe Sta Rite technical support at 888-782-7483 and they should be able to helpyou figure this issue out.
I hope this helps.
Sep 12, 2011 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta-rite pool heater won't fire...
www.cheappoolproducts.com/.../Max-E-Therm-manual.pdf - United States
https://www.gpspool.com/.../Sta-Rite/Tech%20-STA-%20Servicing%20the%20Heater%20Control%20Board%20%u2013...
Those manual should sort you out.
May 29, 2010 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
Dec 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta-rite lp heater wont start
Its the top. There is a membrane that controls the circuit board....the button pad is bad
Aug 26, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Jun 14, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Sta Rite Maxi Therm 400k Btu Propane Heater  Logo
274 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
