Question about Maytag MAV3905AWW Dependable Clean Top Load Washer
Maytag mav 3905 3 years old will not spin water out of clothes
3 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: Maytag Mav-1 Slow Spin
hi thanks for the question with any washer if you use a hi sud zing detergent it really slows down the spin cycle check this just fill & drain 2or 3 times use some veniger try this thanks the appliance doc
Posted on Sep 17, 2008
richroth
  • 9472 Answers
SOURCE: Maytag mav 3905 3 years
That sounds more like the clutch assembly. The clutch may be worn. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it.
Posted on Dec 01, 2010
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
Maytag mav 3905 3 years old will not spin water Agitator works fine, but will not spin out water when done. Can it possibly be the transmission? Had 1 tech out today that said yes,another tech(where I...
Dec 01, 2010 | Washing Machines
I have a 2002 Maytag MAV7600 washer. Problem
Honestly get a new washer if you got 7 years out of an mav your ahead of the game worst machine maytag ever made, you need a timer but i wouldnt invest the time or money on an MAV
Jul 07, 2009 | Washing Machines
Water built up in Maytag Washer Model MAV-17
I would check the water valves or the water lines. If the water valve is leaking, the water could be running out and following down the cabinet then in to the tub, or the water valve water line that leads right in to the tub there for leaving a water build up.
Mar 01, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Model mav6000awu has a sound of water rushing when machine finished filling and running.started doing this recently.
most maytag toploader mav did have that sound if it drain & spin your ok i have the same washer and it has the same sound & work fine that washer will only last about 10 years (i work for maytag )
Feb 18, 2009 | Maytag Washing Machines
Jul 17, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag mah4000aww motor control board bad cannot tell which series it is serial 53312313yk
my front load washer is leaving water after done spin cycle can still ring water out of clothing....water is draining from hose and is spinning somewhat strange...like its not going through rinse properly sorta like its repeatedly doing same cycle pattern...spins for lil, stops makes running noses...spins sum more....soapy clothing...its 5 years old..but first time use this month finally connected it...when took bottom off to check hose connection noticed control board looked lil warped and brownish colored but not as meant to be..maybe its burnt out?
Apr 13, 2008 | Maytag Washing Machines
CLOTHES STILL SOAKED AFTER SPIN CYCLE
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine, parts are not that expensive, 50-80for bearing kit, here is my site on how to do it http://maytagwasherrepair.googlepages.com/index.html
Apr 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV3905AWW Dependable Clean Top Load Washer Logo
125 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
