Question about Apple MacBook Pro with 17" Display
I've been getting pop-up windows that say I am prevented from opening or changing documents/files due to lack of authorization or permission. I am the owner of and only person using this computer. How can I not be authorized or permitted to access or alter docs files or folders?
    Guru:
  • 206 Answers
I am not sure if the documents or files that you are opening or changing are from attachments sent to you via email or not, but I can suggest that you can try this step:
Right click on one of the affected files and select Get Info.
This will open a long narrow box providing detailed information of the document.
Now look at the bottom of the window under Sharing & Permissions
Click the padlock and enter your User Admin password when the pop up window appears.
This will allow you access to changing the current permissions of this document.
Make sure you see permissions for "Read and Write" attached to your user name.
If you do, then go ahead and close this window. However, if you see only Read permissions attached to your user, then change that to Read and Write.
Once you have done this, close this Get Info window.
Try to launch that affect document to see if it opens now. If it does then this may be a permissions issue that is affecting your documents and files.
Whether you can or not, I would still recommend you still run this procedure below in order to try and fix this permissions issue.
Now run Disk Utility to repair all permissions on your Mac OS X volume.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} -RUN DISK UTILITY-
Go to Finder Menu bar
• Click Go > Utilities > Disk Utility and open up Disk Utility app.
• Click on Macintosh HD volume (or on the name you have changed this volume to.)
• Select "Repair Disk Permissions"
**Let Disk Utilities run this repair permissions until completion
Once Disk Utility is complete and there are no errors in red in the completion summary (if there are errors listed in red, re-run Disk Utility to see if those error will clear- if they don't reply back to this post right away and let me know what the exact error message is), quit Disk Utility.
• Now attempt once again to access the affected documents and files and see if you are able to access these items now.
I hope this helps.
Regards,
-Mactechtrainer
Posted on Feb 11, 2010
How can I get permission to copy file from computer to my external hard drive
You should be able to copy and paste, or simply drag the file to the external hard drive (to make a copy).
Right click on the file, then select 'Copy'. Navigate to your external hard drive and then click 'Paste' to copy the file into it.
If you're talking about something like a word document you may have to change the permissions. To change the permissions right click on the file and then choose PROPERTIES. Change the properties if need be (the permissions..)
The image below is from my computer using Linux .. however the process is the same using Windows. Right click the file .. then choose Properties..
Jan 05, 2016 | Hard Computers & Internet
Tip
How to take ownership of a folder and Grant permissions in Win 7?
Summary:
Windows 7 has implemented addition security mechanism to prevent accidental or intentional file or folder modification by not allowing users other then owner of file or folder to access it. Hence incase if you need to access, modify or delete such files or folder you need to take ownership first then assign rights or permission to respective users. Here is Guide on How to take Ownership and Grant Permission in Window 7.
More Information:
How to Take Ownership in Windows 7?
  1. Locate the file or folder on which you want to take ownership in windows explorer.
  2. Right click on file or folder and select “Properties” from Context Menu.
  3. Click on Security tab.
  4. Click on “Advance” (For special permission or advance settings click advanced).
  5. Now click on Owner tab in Advance Security Settings for User windows.
  6. Click on Edit Button and select user from given Change Owner to list if user or group is not in given list then click on other users or groups. Enter name of user/group and click ok.
  7. Now select User/group and click apply and ok. (Check “Replace owner on subcontainers and objects” if you have files and folder within selected folder).
  8. Click ok when Windows Security Prompt is displayed.
  9. Now Owner name must have changed.
  10. Now click Ok to exist from Properties windows.
Once you have taken the ownership of file or folder next part comes is Granting Permissions to that file/folder or object.
How to Grant Permissions in Windows 7?
  3. Click on Edit button in Properties windows Click ok to confirm UAC elevation request.
  4. Select user/group from permission windows or click add to add other user or group.
  5. Now under Permission section check the rights which you want to grant i.e check “Full Control” under the “Allow” column to assign full access rights control permissions to Administrators group.
  6. Click Ok for changes to take effect and click ok final ok to exit from Properties window.
Now you can access files of folder in windows 7 with full permissions and take full control.
on Mar 26, 2010 | Computers & Internet
I've been trying to use ocr on my Brother DCP-J315W and I get this error message: "Unable to write the file to Destination Folder. Please make sure that you have correct permissions to write to th
Where is the destination folder located is it windows .If Windows
Open file Explore (right click on Start icon select File explorer or explore) Right Click on Folder and check sharing permissions and allowed users.
Jan 03, 2015 | Brother DCP-J315W Inkjet Multifunction...
Need instructions for gps for dummies FD 220
Hello
I've the user manual for your GPS device; Dummies FD-220. I've askde you to send your email address by fixya comment box 22 hours ago; since I'm following this problem post. You haven't send it to me till yet. It is in PDF format, and this window does not allow me to upload PDF files by it. I've the permission from FixYa to get your Email address and send the document to you. I've asked you about the email address 22 hours ago, and you haven't send me till yet. Then where should I send this document by Email. this is an Email solution, that you have posted to get an answer. Send your Email ID now to me by FixYa comment box. I'm here ready to post you the solution. OK.
Oct 18, 2011 | GPS
BUILT IN SKYPE CANNOT OPEN
is this linux or windows operating system ?
i can help you but i need more info on this...
if it is windows check your "uac" permissions
if is linux like OS check your sudo permissions and also check the access permission of the file
ls -all --- to list files
chmod ---- to change the file permissions
./file --- to execute the binary
May 27, 2011 | Computers & Internet
Cannot save a word 2010 file due to permission error
> permission error
Change the "target" folder to your 'My Documents' folder, since Windows gives you permission to write into that folder.
Feb 17, 2011 | Dell Studio XPS 1640 Notebook
How can i set up network file sharing
First step is to check if the file sharing option is checked in my computer folder options.
Start- My computer- TOOLS - FOLDER OPTIONS- and click on the second tab VIEW- scroll down to the last option which will show as USE SIMPLE FILE SHARING.
Level 1: My Documents (Private) loadTOCNode(3, 'moreinformation'); The owner of the file or folder has read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. All subfolders that are contained in a folder that is marked as private remain private unless you change the parent folder permissions.
If you are a Computer Administrator and create a user password for your account by using the User Accounts Control Panel tool, you are prompted to make your files and folder private.
Note The option to make a folder private (Level 1) is available only to a user account in its own My Documents folder.
To configure a folder and all the files in it to Level 1, follow these steps:
  1. Right-click the folder, and then click Sharing and Security.
  2. Select the Make this Folder Private check box, and then click OK.
Local NTFS Permissions:
  • Owner: Full Control
  • System: Full Control
Network Share Permissions:
  • Not Shared
Level 2 (Default): My Documents (Default) loadTOCNode(3, 'moreinformation'); The owner of the file or folder and local Computer Administrators have read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. This is the default setting for all the folders and files in each user's My Documents folder.
To configure a folder and all the files in it to Level 2, follow these steps:
  2. Make sure that both the Make this Folder Private and the Share this folder on the network check boxes are cleared, and then click OK.
  • Administrators: Full Control
  • Not Shared
Level 3: Files in shared documents available to local users loadTOCNode(3, 'moreinformation'); Files are shared with users who log on to the computer locally. Local Computer Administrators can read, write, and delete the files in the Shared Documents folder. Restricted Users can only read the files in the Shared Documents folder. In Windows XP Professional, Power Users may also read, write, or delete any files in the Shared Documents Folder. The Power Users group is available only in Windows XP Professional. Remote users cannot access folders or files at Level 3. To allow remote users to access files, you must share them out on the network (Level 4 or 5).
To configure a file or a folder and all the files in it to Level 3, start Microsoft Windows Explorer, and then copy or move the file or folder to the Shared Documents folder under My Computer.
  • Power Users: Change
  • Restricted Users: Read
  • Not Shared
Level 4: Shared on the Network (Read-Only) loadTOCNode(3, 'moreinformation'); Files are shared for everyone to read on the network. All local users, including the Guest account, can read the files. But they cannot modify the contents. Any user can read and change your files.
To configure a folder and all the files in it to Level 4, follow these steps:
  2. Click to select the Share this folder on the network check box
  3. Click to clear the Allow network users to change my files check box, and then click OK.
  • Everyone: Read
  • Everyone: Read
Level 5: Shared on the network (Read and Write) loadTOCNode(3, 'moreinformation'); This level is the most available and least secure access level. Any user (local or remote) can read, write, change, or delete a file in a folder shared at this access level. We recommend that this level be used only for a closed network that has a firewall configured. All local users including the Guest account can also read and modify the files.
To configure a folder and all the files in it to Level 5, follow these steps:
  2. Click to select the Share this folder on the network check box, and then click OK.
  • Everyone: Change
  • Everyone: Full Control
Note All NTFS permissions that refer to Everyone include the Guest account.
All the levels that this article describes are mutually exclusive. Private folders (Level 1) cannot be shared unless they are no longer private. Shared folders (Level 4 and 5) cannot be made private until they are unshared.
If you create a folder in the Shared Documents folder (Level 3), share it on the network, and then allow network users to change your files (Level 5), the permissions for Level 5 are effective for the folder, the files in that folder, and the subfolders. The other files and folders in the Shared Documents folder remain configured at Level 3.
Jul 20, 2010 | Microsoft Windows Vista Ultimate Edition
I am unable to print pdf documents on my Image Class d880 printer. I used to be able to...but am not able to anymore. Any reason why this is happening?
Maybe your pdf is protected by print password, in this case, you have to use the pdf password remover to remove the print permission.Here is tutorial on how to remove it on windows:
http://www.pdfpasswordremover-mac.com/pdf-password-remover.html
Jul 12, 2010 | Canon imageCLASS D880 All-In-One Laser...
My printer won't print ADOBE files, but prints all word documents
I believe you are misunderstanding what you're "telling" the computer to do. You are telling the computer (I assume in Microsoft Word, but perhaps elsewhere) to generate an electronic document in PDF format. (I believe PDF stands for Portable Document Format)
It uses a printing metaphor because like a paper copy, the PDF file is designed for people to read, not edit the document you have created. Also, some PDF-making software methods involve pretending to be a printer, which allows the user to make a PDF file in any program that would normally only output your work to a printer.
Most people, when wanting to print a PDF document onto paper, open it with Adobe's Acrobat Reader (which is free software) and print the document from there. For sharing a document that you want no changes to, this is a superior option to sending people an MS Word .doc (or .docx) file, which does not have its information "locked" onto virtual pages in the file.
I hope this helped!
Jan 18, 2010 | HP DeskJet F380 All-In-One Printer
Printer is Ready - PDf document has permission that do not allow printing
PDF Password Remover has the ability to remove the restrictions, permissions and security on editing, copying, printing with effortless.
Jun 09, 2009 | HP PSC 1315 All-In-One InkJet Printer
Apple MacBook Pro with 17" Display Logo
125 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
