Question about ASUS P5GPL Motherboard
ASUS P5GPL - Ram Capacity
Hi i have p4 system with 512MB DDR..........i just wanted to know is it possible to add another 1gb ram in same system...........will it suport.
    Scholar:
  • 148 Answers
If there is additional ram slots it will definitely support but the ram speed should be the same,like if u use the ram as 133mhz ,u should use the ram with same speed .
Posted on Feb 21, 2008
My mboard have 4 slot of RAM DDR, but i can't put all my RAM on all (4) slot, only 3 slot my comp can read (my RAM is DDR 512 MB pc3200 x 4) soo.. i have 1 Free DDR 512 and 1 slot.. please..please guide...
Looks like you have the right kind...they have to match you know...you could try 2/1g sticks instead...
Your compatible memory is here: http://www.crucial.com/usa/en/compatible-upgrade-for/ASUS/p5gpl-x
Jul 22, 2017 | ASUS P5GPL-X SE Motherboard
I have 2 questions:- 1. I have a hard disk of 80GB capacity.I want to augment my storage capacity with an additional Hard Disk of 500GB in the second slot of my CPU.Will my motherboard support that.My...
The motherboard has 2 memory slots with each slot allowing up to 1GB modules of DDR PC2700, DDR PC3200, DDR2 PC2-5300 with a maximum of 1GB per slot. Do not mix RAM speeds.
As for hard drives, the board has the capacity of:
PATA (Parallel) - 2 x ATA100 4 Dev. Max
SATA 1.5 Gb/s - 2
I would assume that the 500GB drive you have is a SATA drive. and the 80GB as PATA. If that is the case, then the two drives would be on different controllers and would work in the system. Typically, it is recommended that the SATA drives is the main hard drive holding your OS.
As always, you would need an open bay in your computer case as well as adequate power to the PWS to complete the installation.
Nov 19, 2010 | ASUS P5VDC-X Motherboard
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
RAM memory expand modules
sir..thanks for more information abut your unit..the best memory u need is 1gig DDR1 or (X2)times two 512Mb DDR1 PC400 memory..Thanks and Good Luck...^_^..Have a nice Day Sir..
May 17, 2009 | Compaq D51C PC Desktop
Need to add RAM
Located here is the actual specifications of your W3052.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W3052
The DDR means "double data rate", SDRAM is "synchronous dynamic random access memory" and DIMM is for "dual inline memory module". These are the way manufacturers describe the specific speed, type, and packaging of the memory. You need to get the correct combination for your computer in order for it to function properly. The PC2100 is NOT correct, at the very least it will slow your computer down, and possibly will not work at all. You should use PC2700.
If you wish to add another 512MB taking your computer to 1GB total, then you only need 1 module, a 512MB, like the one that came in the computer. Do not purchase a 1GB module expecting it to work properly with the one already there. It probably won't. If you want to max out your computer's memory taking it to 2GB, then you will need to purchase 2 each 1GB modules, and remove the existing 512MB module.
When you go to the computer store, you ask for either "one five-hundred-twelve megabyte, PC2700, DDR, SDRAM DIMM memory module" or "two one-gigabyte, PC2700, DDR, SDRAM DIMM memory modules".
The part numbers from, Kingston, one of the major add-on memory makers are shown here:
512MB = KVR333X64C25/512
1GB = KVR333X64C25/1G
Mar 28, 2009 | E-Machines eMachines Desktop PC
Memory problem
It's possible that the new RAM is incompatible with your motherboard. Check board specs to see list of supported RAM & check against what you have. Hope this helps.
Dec 23, 2008 | Microsoft Windows Server Standard 2003 for...
Intel 845 gvsr memory problems
Sounds like the RAM is not compatible. Try another 1 GB chip from same manufacturer & see if that helps.
Dec 20, 2008 | Computers & Internet
Upgrade from 512MB to 1GB
The specs on the memory are correct, so you purchased the correct type of memory for this motherboard. If your getting no video when you power on with the 1gb stick, I would be willing to bet the 1gb stick is bad. Can you return it and try another stick?
Mar 15, 2008 | ASUS P4B266 Motherboard
Which RAM supports
hi!good pm...hope this will help...
check your RAM,look for stickers that indicates your memory speed & capacity (e.g. 512MB PC400 DDR)...if there's no sticker description count the pin,a DDR has a 184-pin DIMM...
googdluck!
Feb 07, 2008 | ASUS P4GE-MX Motherboard
ASUS P5GPL Motherboard Logo
191 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
