Question about Kenmore 21.0 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Myice makeris not working .it sounds like it is trying to dump the ice but no ice and can;t hear water is there a plug or something that should be unplugged .it was reconditioned and came with no manual
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hdg4
Posted on Sep 30, 2010
Ice Maker fails on occasions to dump ice before water is dispensed
monitor the cycle as it is filling water does it over fill or is there a seepage that continue to drip, it could be the water valve. Also do you hear the tray making noise as it tries to dump the ice "the harvest cycle" try to watch it to see if it is a mechanical gearing problem
Nov 19, 2013 | Refrigerators
Manitowoc ice maker
sounds like your dump valve is stuck
Nov 09, 2013 | Kitchen Appliances - Others
My ice maker was not dumping ice from the tray. I removed the ice maker and rinsed it with water. I allowed it to dry and reinstalled it and ice still would not dump. I did some research and found out they...
It sounds like the water inlet for your ice maker is now frozen. Blast a hair dryer around the waterinlet to the ice maker for 5-10 minutes, reconnect the ice-maker and you should hear the sweet sound of flowing water
Jan 25, 2011 | Whirlpool ED2FHEXN Side by Side...
Water works on door but ice maker isn't making ice occasionally hear noise like trying to dump ice cubes but no ice
the water valve located on the back of the refrigerator that the water line is connected to could be bad. if no water is coming to the ice maker then it shouldn't have any ice or water in the ice mold. if it is empty you can try pouring enough water in the mold to make ice cubes. wait an hour or so and see if the ice maker dumps the ice. if it does you probably have a bad water valve.
if your ice maker has ice in it but had been making small cubes you should check to make sure you don't have a jam. small cubes could be from low water pressure or a blockage. if your refrigerator has a water filter it may be time to replace it if the water dispenser water pressure is also low.
May 28, 2010 | Hotpoint HSM25GFRSA
I have a Thermador refrigerator model tss48dab. It stop making ice. I'm not sure if it the ice maker or something else.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 01, 2009 | Refrigerators
Ice maker is not working. Our freezer fridge side by side is about 8 yrs old...and now the ice maker is not making ice cubes. It is as if no water is getting to the machine. I have turned the...
Aug 29, 2009 | Freezers
No ice
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will make the switch to start the cycle.
Aug 19, 2009 | Refrigerators
532 ice maker works, but dumps water into ice container with ice.
Do you still have a manual or can tell me the watts power consumption of the 532?
I'll look into your question. Sounds like a sticking icemaker water valve, but I'll have a look.
Mar 03, 2009 | Sub-Zero 632 / S
Kenmore Coldspot not making ice
sounds like the flap that u can usually hear once the ice has stoppped coming out it sounds like a pop or thud ...what happens is the magnet goes bad and keeps the ice maker constantly open to the outside air causing ice melting and massive ice cubes.....usually a costly repair...check and lemme know
ps. id have a licenced repair guy check it out
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Open Questions:
Refrigerators Logo
47 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
