Question about Jenn-Air JCB2285HES Side by Side Refrigerator
I have a Jenn Air JCB2285HES. The freezer and fridge were not cooling. The digital display read "-" and could not be adjusted using the up/down arrow buttons. I unplugged and plugged the fridge back in and now it is working fine, but would like to know: - what caused this? - what can I do to stop this happening in the future? Many thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that the issue might have happened due to power surge. You can also try to leave it unplugged for 8-12 hrs. so that it melts any ice that’s there, you can also try to clean the condenser coils just to avoid that this issue doesn’t return. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 06, 2010
My Jenn Air JCB2285HES not cool on both sides not frozen line
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
jljhfjg
Oct 21, 2009 | Jenn-Air JCB2285HES Side by Side...
Jenn-air JCD2289ATW Freezer perfect but refrigerator is warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Jenn-Air JSD2789GES Side by Side...
Side by side freezer door pops open
This is a problem inherent with lots of refrigerators. Side by side or top freezer. The rush of air pops the doors. You might want to adjust the pitch of the box by adjusting the front wheels to a higher level.
Jun 17, 2009 | Jenn-Air JCB2280HES Side by Side...
Frig not stayng cool. Freezer not freezing
most fridges have a evaporator dish or container.
it must be emptied ...and cleaned and disinfected.
now-a -days they are usually mated with the compressor and cool this unit down. notice there is no coil along the back of the fridge...it is usiually behind the fridge at the bottom with a cardboard or plastic access cover...
this will make the unit cool better and return the cooling to normal....
\next
clean out your freezer...i bet it's full of 4 month old packs of something you'll never eat....this will let the freezer breathe and circulate air to the coil ...i bet it has 3 in of ice on it...yikes...your not alone...most people do this...\
get a freezer if your getting ready for the apocalypse and liberate some room.
good luck
May 18, 2009 | Jenn-Air Jenn Air Side by Side Counter...
Jenn-Air JCB2389GRS Fridge not cooling properly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
puiodf
Mar 15, 2009 | Jenn-Air JCD2389G Side by Side...
FRidge and Freezer not cooling
I had the same promblem on my Jenn-Air. I replaced the relay on the compressor and fixed the problem.
Jan 06, 2009 | Jenn-Air JSD2789GES Side by Side...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Freezer working Fridge NOT COOLING
fridge takes its coldnest from the freezer check if the fan is running or if the vent is close
May 12, 2007 | Jenn-Air JFC2089HE French Door...
Jenn-Air JCB2285HES Side by Side Refrigerator Logo
37 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
