Question about Nextel i836
Blank screens inside and out
I have a i836 and the outside display and the inside screen went blank out of no where. Everything else works fine. How to fix??
  • Amy911 Nov 18, 2008
    My outside display works---so I at least can see who is calling, but the inside one is blacked out entirely.
    Problem Solver:
  • 5 Answers
Go get an old phone just like yours and change the faces
Posted on Nov 06, 2009
I have a blank screen, nothing will display on screen
What happened for it to get an blank screen. Did you drop it in down. If so there are possible chances that the display IC would have been dislocated from the circuit board.If so we have to test the board with sophisticated test equipments and check it out and you will need the help of an repair center to do.
Keep the screen under an light and see if you can see the screen , if so then the back-light alone has failed which can be replaced at a cheap cost.
Nov 22, 2010 | Nextel i836
Just got my Samsung Impression and it was working fine until the screen randomly went blank. When I turn the phone on I see the start up for about 3 seconds and it turns off. I can take photos and I see...
Hi,what makes Samsung impression phone to go blank is because the flex of the phone is damaged.
The flex of the phone is located inside the phone, connected to the screen board and allows the screen to display.
When the flex get cut or damaged it will make the phone not to display.
So you will need to replace the flex of the phone and problemwillbe solved.
Take care.
Oct 07, 2010 | Cell Phones
My problem is my inside screen went blank white. About a week ago the inside screen started to do weird stuff like one day it had multi colored snow. The next it went blank. The next it looked like liquid...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Oct 05, 2010 | Motorola Mobility E815
Sound but no vision, black screen
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 25, 2009 | Sony Televison & Video
Nextel i576 blank scree, batery fine
how to reset blank screen on nextel i576
Aug 03, 2009 | Nextel i836
Env2 LG phone...
You lost your screen display, just go to service centre if you have warranty. They will replave it
Jun 03, 2009 | Cell Phones
Blank screen
pull the battery from it for a little while , if that don't do it its probably a display chip inside and it can't be replaced , they have been having problems with the screens on these phones , does the phone still work for recieving and sending calls? its not likely but not impossible the screen went
Oct 10, 2008 | LG Shine KE970 Cellular Phone
Screen
If the inside screen and the outside screen is blank, the possible problem is the LCD flex cable. But if the outside sceen is on
but the large inside screen is blank. The large screen could be defective.
Aug 11, 2008 | Motorola Mobility V300
Blank screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Aug 27, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Cell Phones Logo
382 people viewed this question
Top Nextel Cell Phones Experts
Rommel Balcita
Shehu Pro
Shehu Pro
Computer Repairing
Computer Repairing
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
