lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
- Turn the Television On.
- Press and hold the clear TV button for six seconds until the LED flashes.
- Enter the three-digit code using the buttons on the number pad.
- Press #.
Note: The LED will flash three times.
- Test functionality with the TV.
- Return to Step 2 if the remote is not able to turn the TV On/Off, change the
volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
- Press and release the red TV Power button.
- Press and release the Up or Down Arrow on the remote until the television
turns off once every second.
- After the television turns off, press and release the # button.
The tv signal comes from the Direct TV box.
The sound in gone from all chanels and the signal comes from a DirectTV box.
