Question about Samsung Remote Control
I try to start the tv and all I hear is a slight squeeling noise, think it is the color wheel. I just bought a new lamp. the tv makes the noise it initially makes telling me it is trying to start but two blinking lights appear in the front. The lights are the power and temp lights.
  • patrick_olso Feb 06, 2010
    I did not reset the lamp hours, how do I do that?
  • 11,896 Answers
If you hear a squeeling noise, then that would be your color wheel. When you replaced the lamp, did you reset the lamp hours? Did you check the power from ballast with a voltmeter to see if you are getting power to the lamp?
Posted on Feb 06, 2010
Install new lamp, nothing comes on ,change back to old lamp still nothing
Hi,If the lamp didn't do the work it could be that the problem is with something else.If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Do you hear buzzing or high pitch sounds? If you do it could be a problem with the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Make sure the door cover is properly shut other wise it wont lamp light up.
Apr 05, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
We own a Samsung DLP-TV. Last night it started shutting itself off. WE changed the lamp, but it is still shutting itself off after a minute. First, the picture goes off black, then the entire TV shuts off....
Do you still have your old lamp? try to see if it still works.. i think the problem could be something with your Ballast or maybe the color wheel.
Does your TV makes a strange sound? if it does maybe one of those 2 ballast or color wheel.
LETS TRY THIS....... MAYBE IT WILL WORK.
the Door lamp switch could be faulty, you've got to check it need to close fine with out the switch to go down
here is a picture that i found it looks like this!
and if not.. you can probably call this number the will give you free service.. i have tried it before =] (800) 281-8860
Mar 09, 2010 | Samsung HL-T5675S Television
I have a Samsung DLP 50 inch tv, model #HLP5063wx xaa. A friend gave me the tv, and told me it wasn't working, probably needed a new lamp. When I try to power on the tv, it comes on but makes a terrible...
the lamp led will light when the color wheel is defective. If the noise you hear is a buzzing or screeching the color wheel is the most likely cause.
Sep 10, 2009 | Televison & Video
Samsung HLP4663W 46 in. fan noise when shutting off.
it is definately the color wheel, unplug it and don't turn it back on
Dec 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Tv work come on , all 3 lights blinking
All 3 leds blinking is a Lamp error. Pull the lamp and see if it is blown. If so, replace. This error can also be caused by many parts of the optical block = colorwheel, balast, or DMD board. If you hear a buzz sound when it tries to fire lamp then the lamp is bad. If not listen for the spinning high pitched squeel of the colorwheel coming up. If you hear this but no buzz from the ballast, you likely have a bad ballast. If you do not hear the color wheel, you have a bad color wheel or DMD board.
Dec 07, 2008 | Akai Televison & Video
Color fades out on tv
I have the same tv and the same problem (color banding, incorrect colors, colors blinking) occured after I replaced the lamp. I had a tv repairman take a look at my unit and he said the color index was incorrect, the tv doesn't know the correct colors to display. The best way to fix that problem is to replace the "light engine". The repairman replaced the "light engine" to my tv and everything is working great. My tv was still until warrenty so I don't know how much a new "light engine" would have cost.
Jul 27, 2008 | Mitsubishi WD-73732 73" Television
I have a Samsung 61 inch DLP tv. Was very happy with it for the past 3 years. Lamp went out in Feb. Got a new one and replaced. A few weeks ago, it started making a screeching noise. Fans were ok,...
It is b.s. but it's not only samsung that have poor reliability. At least they have some customer service. Some new brands are a nightmare. I would suggest changing the ballast first, and if that doesn't do it, you're probably looking at a dmd board which is very expensive. Only other thing I can say is to try removing and reseating the lamp switch again. Also listen for the color wheel to start up a few seconds after you push power on. Color wheel is started by dmd board, lamp is driven by ballast.
Jun 12, 2008 | Samsung Televison & Video
Loud noise
I believe it is the color wheel. The motor might be going bad or it has dirt or dust in it.
I hope this helps
Shuttle83
Nov 06, 2007 | Toshiba 62HM95 62" HDTV
Samsung Remote Control Logo
118 people viewed this question
Jerry Greenberg
Jerry Greenberg
