Question about Philips 43P8341 43" Rear Projection Television
The tv powers up but than it turns off. I was told it was the the mother board. I think its called the pci card but I could be wrong. I was wondering where I could get that part?
Hi I have SRM Mother board which VGA is suitable for this Please help me Prak
Tell me the exact modle of your srm mother board .is the vga interface agp or pci or pci express? by the way, some vga card need extra power surply.
Oct 28, 2010 | Vga GeForce4 Ti4200 64MB DVIout AGP Card...
All supply are ok on mother board but dont display
check your memory and other PCI cards... check it one by one.. take it all out and try it one bye one..
i think there's a pci or a memory damage..
Oct 22, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My mother board is total dead i can check all type of card level which fault is in my mother board
try
PC POST Diagnostic Test Card Motherboard Analyzer for PCI Slot 2 Digits /
USB Motherboard Test Card/
Desktop Motherboard Diagnostic Card .... These are used to test & diagnose motherboard problems. PC Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot various problems of compatible PCs by using the PCI slot. With this card in hand, you no longer have to go through tedious and time consuming process of trying to figure out what is wrong with your hardware. PC Diagnostic Card will indicate exactly what is wrong with your PC in just seconds
Apr 16, 2010 | Intel Motherboard
When my tv is on for about 15 mins the borders turn green. I have changed the hdmi cable and it hasn't fixed the problem. My tv is a 47" vizio 1080 and it's only 4 or 5 months old. can you help?
something is wrong call vizio i bought the same tv two days later all of the color on the screen that should be black is green called repairman who came tv was working and after he replaced the mother board and daughter board tv was black turned on but no pic he tried again and i heard the arching sound he zapped it i was told by repair we need to order the power board it willl be another 3 to 5 days
i called vizio the minute that he left i was so pissed and that is not like me they are sending a new tv that was thursday i still have to wait 7 to 10 days but they are standing behind there tv i will give them that
Jun 04, 2009 | Vizio SV470XVT 47 in. LCD TV
Computer is not functioning
H!
Please check the lock of your processor. If it is tight or loose. If it is loose then it is the one causing the mother board no to function properly. You must tighten it to make it stable. After checking and it is not the reason for the malfunctioning of the system. Try to remove your CMOS battery and then clean, and remove also your memory card in the mother board and clean. Return it after cleaning and then close the CPU and turn it on. During the booting process strike the delete key to enter into bios set up. Adjust the time/ date settings to your current time. Press F10 then enter. wait for the CPU to process.
Please post any comment if it was solve so that I can give you more option if it does not solve your problem.
jonags3
Apr 17, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Cannot get comp to install resource cd
pls take out all pci cards and have u installed AGP for VGA instead of in built tell me the make of ur vga , i think i can help u in this the first blue screen thing u were facing was not ur motherboard infact ur RAM u have changed it it should be gone even on ur old system, u have also changed the hard drive it has nothing to do with freezing thing u were facing ok
tell me how many pci cards have u installed in ur system and what abt VGA is it in built on mother board or additionally fixed by u , actually something is faulty and it is causing u trouble in hardware kindly do this
take all pci cards out modem , sound,tv card
use new RAM chips
just install RAM and VGA to start take out all drives like dvd or cd just leave one for installation the newest one
u can use ur old hardrive or new i dont feel it is ur hard rive
and then try to install OS without pci cards if u have
check the CPU fan is it running and also check the Casing Fan also
pls tell me the results
if not resolved tell me the whole config of ur system what u have inside
i can solve ur problem if u want
regards
Feb 28, 2009 | Dell Dimension 4300 PC Desktop
Intel D101GGC Motherboard PCI Express compatibility issues........
i'm using NVIDIA GEFORCE 8600 GT on my d101ggc board and its working fine
Jun 30, 2008 | Intel D101GGC Motherboard
Wirring for my mother board
The board may have tiny words printed on it telling you what the plugs are.
Most newer boards are fool proof in that only the specified cables can be plugged in. generally the Hard drive plugs into IDE 1 or MAIN and CD drives plug into IDE 2
Video cards go into the First slot usually. It may be AGP or PCI or PCI express depending on the board. The extra PCI slots are for extra devices like NIC cards and Sound card. Power cables cant be plugged in wrong because there male to female and only fit into there designed plugs.
Make sure the motherboard is installed correctly and is not touching the actaul case but held up with spacers. you can find these at most Computer stores.
Really try and find the manual online if you can. It may be necesary when plugging in the little pins for the power switch and USB pins.
good luck.
Jun 12, 2008 | Lenovo Computers & Internet
Mother board
Firstly your motherboard doesn't have video capabilities built in so you have an addon video card. I doubt there's any problem with the board as it's jumperless and you can't have the CPU settings wrong. Are you getting any beeps when you switch on? The length and number of beeps can tell you where the problem is. The usual problem with no video is either a memory problem or video card problem. If you can borrow another video card try it. Make sure the plug is correctly inserted all the way in and make sure the video card is properly seated in it's slot. I assume you're using the 4x AGP slot. Remove that and try another ot even a PCI card in the PCI slots. You may then get a picture. Actually apart from finding it hard to figure out your actual problem it's very hard to diagnose a fault from the little you've told me. Certainly the motherboard can be faulty and you won't get video but it's the video card you should be looking at first. Have you turned the monitor on and plugged it in?
Jun 03, 2006 | Acer AOpen AX 6B Plus (91.87810.321)...
Philips 43P8341 43" Rear Projection Television Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
